Watches Logo
A
Anonymous Posted on Sep 20, 2013
How to adjust the time on casio watch AW 90H 7BV
5 Related Answers
Anonymous
  • Posted on Dec 11, 2008
SOURCE: Casio watch
Press MODE until you reach H-S (e.g. A 11:00 with seconds on top)
Press and hold ADJUST for 3 seconds until H-S blinks
Press and hold SEARCH for every movement; you may wanna press LIGHT so the hands will move freely. Press ADJUST again to when desired time was reached
Anonymous
  • 2501 Answers
  • Posted on Jan 30, 2010
SOURCE: analog time setting
On the assumption that my Casio watch works the same as yours, press the mode button (lower left), until "HS"appears, then use the buttons on the right to advance or ****** the hands.
If this does not do the trick, then go to the Casio web site "casio.com" select "support"then "manuals"; accept terms and conditions and the select "watch manual archive"
Insert the required number off the back of your watch and download the instructions.
Anonymous
  • 714 Answers
  • Posted on Feb 23, 2010
SOURCE: casio aw-82
http://world.casio.com/wat/download/en/manual/
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Anonymous
  • 2501 Answers
  • Posted on Mar 08, 2010
SOURCE: adjust the time in a casio g-shock shock resist watch
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
ansel_albert
Ansel Alberto
  • 248 Answers
  • Posted on Sep 08, 2011
SOURCE: how to set the time for casio aw-591(4778) details
press and hold adjust button until digits flash (the digit that flashing is changeable by reverse and forward) mode is to choose what you are about to change. if your done with the digital time, press adjust once. for analogue time: press mode button until it reaches the word "H.SET" press and hold the adjust button then the word H.SET replaced by the time that you had been set for the digital time. then you can now use the reverse or forward to set the analogue time. if your done press the adjust button once then the mode button once. i hope i had been helped you.
Wvq 200ha Waveceptor features and settings. Do I just wait for auto reset. Is their a time zone setting
Casio are very good at providing manuals. I assume your model is the WVQ200HLA - if that's the case go to http://www.casio.com/products/watches/wave-ceptor/wvq200hla-7bv
and you'll see a link at the bottom of the page to download a PDF manual. If that's not the correct model, then go to
http://waveceptor.casio.com/support/manual/http://waveceptor.casio.com/support/manual/
OK?
Nov 10, 2017 • Watches
24helpful
2answers
How to set the time for casio aw-591(4778) details about mode,adjust ,reverse and forward
13helpful
2answers
I lost my manual for casiofishing gear aw82 watch. tell me how to adjust digital and analog time and date
For all those who lost their Casio watch manual. Follow this link, fill in the requested details and download manual. http://world.casio.com/wat/download/en/manual/
10helpful
How do i adjust the hands on my casio AW-81 watch please?
push the mode button to the h-s mode, then hold down the adjust button for 3 second then you can adjust the hand by using the search button only
Trouble shooting for baby-g shock BG1500A-7BV
hold the mode button for a few seconds untill tyhe numbers flash and use the start and stop buttons to change time
1helpful
How do I reset?
follow this link and download manual:
Rate me, please.
31helpful
3answers
Casio watch
Remove few pieces in my Casio AW-SD bracelet
What u can do is call casio tech support and give them ur email address and they can send you the instructions to adjust your band.
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
