It doesn’t work I don’t understand why
R and R on off switch. If it is bad it will still light up 90% of the time.
Possibly the temperature sensor is faulty(out of spec.) and it will cause that problem or the display unit is faulty. Suggest you replace both if you decide to replace the display.
No. 90% of the time it is the on off switch.The switch will still light up.You can test it by connecting the 3 white wires together. and then black wire to the 2 gray wires that will by pass the switch unplug freezer first...If you do not get this.Have a professional tech do it.
The switch is $24.30 plus $10.00 for shipping. Arctic Air.(952)941-2270
