I HAVE A NEW 40IN SAMSUNG LCD HD READY TV AND SAMSUNG DVD HOME CINEMA WITH A HDMI AND OPTICAL CABLES FITTED BUT THE SOUND ON THE TV THROUGH THE DVD RECIEVER IS OUT SYNC THE VOICES GO DEEP AND THE SOUND CUTS OUT ALTOGETHER, SOMETIMES IT WORKS FINE AT FIRST THEN IT GOES OUT OF SYNC ETC AS ABOVE. I HAVE BEEN BACK TO THE SHOP BUT NO MUCH HELP WHAT IS THE USE OF THE OPTICAL CABLE OR THIS ANYNET DEVICE ON BOTH IF THE SOUND IS ANNOYING. TV IS LE40R8 DVD HTX30. I HAVE TRIED TO SET THE AV SYNC DIFFERENT AND MOVED THE 5.1 SPEAKERS ALSO NO HELP.
I'VE GOT EXACTLY THE SAME SET UP WITH NO SOUND PROBLEMS.
HOWEVER I'VE JUST PURCHASED A PLASMA 42" SAMSUNG PS-42Q96HD AND CONNECTED IT TO A HT-X30 HOME THEATRE SYSTEM AND WHILST WATCHING DIGITAL TV THE SOUND PROBLEMS YOU DESCRIBE START. HAVE YOU RESOLVED THE PROBLEM OR DO I NEED TO TAKE IT BACK TO CURRY'S?
I just had the same problem. I returned it to currys and got an exchange because I thought there was somethink wrong with the surround sound itself. I have just tried , and left for ages as it goes out of sync gradually as you said ,the red/white cables (rca , i think it's called)and it works perfectely. You can find the wire for quite cheap just type it in google.
SOURCE: optical output on tv through dvd home cinema out of sync
Up front, i copied this from another site, so kudos to the OP there if this works for anyone...
This same problem had been bugging me when I bought my LE37B650,
everyone suggested adjusting the delay time on my AV amp but
unfortunately mine does not have this function.
Anyway I finally fixed the problem using the following steps
Before you start make a note of your menu settings as you will have to reset them after this procedure
Turn off the TV then press Info -> Menu -> Mute in sequence then
turn the TV back on again. This will get you into the secret Service
Menu. Go straight to the AUDIO page of the menu. Don't be tempted to fiddle with things in service menu cos you can end up in a right old pickle!
In the AUDIO page you willl notice that there is a time delay set for
the internal speakers of 100ms but for some reason this is not set for
the external output so all you need do is dial in a 100ms delay there
and that should sort the problem. Well it fixed it for me.
Note that as soon as you enter the service menu, all your other
standard menu settings are lost and the screen will be set to dynamic
for some reason so you have to go through and change everything back
after you have done this.
Hope this Helps
Original link: http://www.hometheaterforum.com/forum/thread/280579/audio-delay-on-samsung-650-lcd-tv
This would suggest that you CAN fix the problem with an analog amp.
Also interested to see if a 2 year old thread is alive!
