Polaroid i733LP Digital Camera Logo
betty boop Posted on Sep 21, 2013
Camera will not power on ,only shows greenlight
kussani p tiempo
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 21, 2013
kussani p tiempo
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
31
Points
Try to change the battery
On my dash of my 3liter v6 1995 pajero there are four greenlights for to show when four by four are ingage.the two front greenlights keeps flashing even when its not in four by four
Flashing super select 4wd lights most often occur when the front differential automatic disconnect is not engaging /dis-engaging when you select/deselect 4x4 drive. Causes are:
- front differential sensor switch is damaged or faulty
- actuator rod/shaft jammed / seized (perhaps sand/mud/dirt)
- vacuum lines leak/popped off fittings
- vacuum solenoid valves (2no.) either maybe faulty
- electrical wiring connection issue (ecu/solenoids/switch)
- combination of the above
Greenlight but no ac out
voltage regulator is bad. Most likey bad caps.
My camera beeps, has a flashing greenlight and has a message on screen - "Turn on and off again". Still does the same, no matter what I do.
Please remove off the battery and keep aside , press down the power and trigger to discharge off any charges present on the circuit.
After 30 minutes load back after confirming on the battery terminals and the memory card ( format if there are images present after downloading them.)
On off switch seems not to work. both greenlight
yes you can fix it on your on.., just remove the battery on your motherboard and put it back
Acer gemstone 7520 17" power on problem greenlight flashing
cd-rom-shows no emmulation-how to repair-fix? tks in advance
Problems connecting to the internet
unplug from power all things then plug back in,in this orderthe modem,then in 2 minutes,the computer,it should reset
10helpful
7answers
Benq dc c500 digital camera dirvers
You can download them from the BenQ site:
http://benq.nl/support/downloads/downloads.cfm/dtype/D/page/downloads/product/830
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
