SOURCE: Can't load Map update on TomTom XL 330S
You'll have to remove enough stuff to make room for the new map. I had the same problem which is how I found this site. Turns out, the new map is larger than the one that came on the unit. The 1 GB of available space is pretty much all used when you get the GPS. Just copy all the voices and POIs that you aren't planning on using to your computer in case you change your mind later (you can just download them again for free too). As for the voices, only one works for text-to-speech anyway and that would be Samantha though a male voice is available for download.
You'll need to clear just under 4 MB to make room for the new map, and that's if you haven't added anything. Having the drive/memory on this unit just larger than the map makes it very difficult to get much use out of TomTom's great add-ons.
SOURCE: Problem with map. You cannot use this map on this device Western_Europe_1GB
Deleted map from Tomtom device and again downloaded map from Tomtom Home. Device working fine.
SOURCE: Problem with map. You can't use this map on this device TOMTOM
It sounds like you are trying to use cracked maps and have not patched the .dll file for your TomTom in TomTom Home. Use yDGpatch to patch the .dlls in TomTom Home
Testimonial: "thanks"
