Problem signature: Problem Event Name: APPCRASH Application Name: UnZipExpress974262.exe Application Version: 15.9.28.27 Application Timestamp: 52332061 Fault Module Name: kernel32.dll Fault Module Version: 6.0.6002.18704 Fault Module Timestamp: 5065cd44 Exception Code: e06d7363 Exception Offset: 0001d8cb OS Version: 6.0.6002.2.2.0.768.3 Locale ID: 1033 Additional Information 1: 88f0 Additional Information 2: 16b6c27d143a63b074f331e24cd32273 Additional Information 3: 1363 Additional Information 4: 94a0e6af9afc87e4b33c8ecca226e3a2 Read our privacy statement: http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
SOURCE: Problem signature: Problem Event
Try this
When prompted, click "Remove driver and driver package."
Answer "Yes" when prompted to delete the driver.
4.You will then see a dialog indicating that driver package information has been collected. Click on the "Delete" button.
5. Back in the printer list, delete the offending printer by clicking on it and pressing the Delete key on your keyboard.
For really stubborn printers that refuse to delete, note the files the printer driver uses and delete them while in safe mode. To do so, on the "Drivers" tab (see above), click the printer and click properties. Sort the "File" column alphabetically by clicking on the heading. Write down the files involved and also write down the "driver path" above the "File" column. Delete these files in safe mode, then repeat the removal procedure above.
OR if problem is due to a corrupted spool queue
Open up c:\windows\system32\spool\PRINTERS
Delete the contents of the directory (not the directory itself).
Retart the print spool service
SOURCE: Close the Programe (Notice)
User permissions issue. Go to C:\program files\microsoft\fsx and find the fsx.exe icon. Right-click it, choose properties, and tick the check box for "always run as administrator". This process doesn't always work doing this from the FSX shortcut.
