Radio Communications Logo
Posted on Sep 17, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Conditional Divert Activation
I have a Cingular C2000 LG phone and rec ently had it unlocked so I could use it in Honduras. I had no problems when I initially arrived and put in the SIM card from my old phone and could make all calls. Now, however, it is blocking one number beginning with "453) and when I dial it says "Conditional Divert Activated" and then followed by "Alert No Answer". I finally figured out the password for this phone (was set at 0000) and changed it but cannot disengage the Cancel All Barrings when I go to Call Barring Services on the Security settings menu. My manual (printed from the internet) says that the barring password functIion is required when you use the Call Barring function (which I never set). The password is obtained from the service provider when you subscribe to this function (which I did not subscribe to). I find several solutions on-line all having to do with entering **'s and a number but I'm not sure which solution is the one for me. Do you know anything about this function and what I can do to turn it off? When I go to Cancel All Barrings and enter my new password it says "Request Fail". I can call all other phone numbers in Honduras but not the 453 numbers - which I could call when I first got here. My husband used the phone a bit after I got here and maybe he hit something - he does not recall - and that instituted the conditional divert activation. I cannot ask for help as I live on an island and there are no service techs or reps here. Please, can you tell me how to turn this function off.
  • 1 more comment
  • hotmamajones Sep 17, 2007
    Here, in Honduras on an island, contacting the server is not an option. I know that the 453 number worked initially and I did not have the conditional divert activated message. I am working with a local service, TIGO, and can call all other numbers and do not get this message.
    What would have to be done to do a phone reset?
    sharon
  • hotmamajones Sep 18, 2007
    I'm not getting any further help here! We run our phones on phone cards so the provider is not going to block my calls. How do I get rid of Conditional divert activation? Surely, for the extra money I had to pay to talk to someone, you can come up with an answer. There were several "codes" to use when I checked Cingular's site, I just didn't know what to use or what they would do.
    don't know why my commnents are posted Sept. 17th and 18th as it is still the 17th. Give me some help please.
Anonymous
Level 2:
  • Expert 78 Answers
  • Posted on Sep 17, 2007
Anonymous
Expert
Level 2:
Answers
78
Questions
0
Helped
26740
Points
190
Have you tried contacting your service provider to enquire as to if they are blocking the 453 number and not your phone? Are you sure your service is working "local" i.e when you phone someone are you phoning via the local mobile service or is it routed via your mobile service from wherever you come from to honduras? You could also try doing a phone reset.
  • Anonymous Sep 21, 2007
    The phone reset should be in the phone setup options.
    You'r only option may be to contact your service provider as the problem may NOT be your phone or its settings. The fact that it originally worked may have triggered something at the service provider or the service took a while to activate on your phone!
3answers
I need restriction code for my LG phone cingular has a Tmobil sim card
you can get the codes from your service provider itself if your phone is 6 months. else you can purchase codes from third party vendors. i got one from here. Superunlockcodes.com
What restriction code of lg cingular c2000?
code
model:c2000
fcc id:bej2000
ime i:010628-00-540533-3
s/n:509cqbd40533-cgr-p64
made in china
I need a restriction code
bhai meray c2000 mobile ka phone restictiancode kaisay khoolaiga
2answers
Lg c2000 need restriction code
LG C2OOO ,IME -010742-00-273010-7 .REQUIRE THE RESTRICTION CODE
2answers
Tone And Message
Call Divert
The GSM standard knows two kinds of call divert:
  • Unconditional call divert
  • Conditional call divert
Conditional call divert occurs on any of three conditions:
  • Divert if no answer after 'x' seconds
  • Divert if unavailable (cellphone switched off or out of range)
  • Divert if line busy
Furthermore, the GSM standard knows three different types of call:
  • Voice call: normal communications when you pick up the phone to talk to someone.
  • Fax calls: the GSM terminal being called is a fax machine.
  • Data calls: your cellphone is acting as a modem hooked up to a computer accepting inbound data from elsewhere.
Each call type is assigned a number: 11 for voice calls, 13 for fax calls, 25 for data calls.
You can activate or cancel conditional call divert on your device. To do so:
##62# : Cancel divert for all call types
##62*11# : Cancel divert for voice calls
##62*13# : Cancel divert for fax calls
##62*25# : Cancel divert for data calls
This code does not hurt your device only helps it to tell it what to do in certain situation of a voice, data, or fax call.
This is a link to a site which goes a little more in depth with the meaning of conditional/unconditional call diverting is. Hope this helps!!!
2answers
Need unlock code for lg c2000 cingular was service
I contacted an att operator. They game me the code with no problem. First power off phone. Remove old sim card. Insert new card and power on. You then select cancel when the message pops up. Enter phone restriction code 20574804. Phone is unlocked
2answers
Unlock
Lg C3310 network unlock method.
For diffrent lg models unlock codes are diffrent. here you will get free Lg unlock codes for various methods. below is method for how to unlock network lock.
· Enter code into the main screen 2945#*7101#
· Clear back to the main screen
· Go to the menu, then Settings
· Go to the Security settings
· Go to Sim Locks
· Go to Network or Network subset
· Deactivate OK
· Phone will display "Enter NSCK" - enter lg unlock code from CM and press OK
· Phone screen will display DONE
Lg c2000 cell phone need to unlock
Are you willing to spend $28 tounlock it? and yet keep the tool to unlock others? If so email me @ [email protected].
Top LG Radio Communications Experts
ADMIN Andrew
ADMIN Andrew
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
