Have a Problem with game pro evolution soccer 2014 its run on my Intel card but i have a NVIDIA card also my laptop is acer with NVIDIA Geforce 610 M and this game pro evolution soccer 2014 run by intel please help me on this problem however i have already install the last version of the NVIDIA update help me and thank you .
SOURCE: EVGA GeForce 6200LE halt the system
in my opinion it's a hardware malfunction, try reinstall the graphic card and before that wipe the cards contacts with pure ethilic alcool (96% vol) then put it back in.
And by the way try using a set of diferent drivers both mobo and graphic
Regards :)
SOURCE: Is my Motherboard compatible?
Try to find out what the AGP voltage is on the motherboard.
Some graphics cards use 1.5 volts and some use 3.
If it's a 1.5 volt AGP slot and you plug a 3 volt graphics card in, it either wont work or you could permanantly damage both card and motherboard.
SOURCE: ATI RADEON X1650 Pro Problem
The graphics card might not be working in sync with your processor. Get it checked WHY this is happening. Probably a faulty connection somewhere. See if you can find one before getting it checked.
SOURCE: can I run two EVGA GeForce 260 GTS cards in crossfire on an ASUS Rampage MOBO?
This is an excellent question, basically "Can you run two Nvidia cards on a cross fire motherboard in a SLI configuration". My first thought was "No" but you should be able to still run a single Nvidia card.
From everything that I have collected the above is correct. Here is a reputable site that you can trust which has a spill on whether you can do this: http://www.tomshardware.com/forum/246903-33-nvidia-graphics-card-crossfire-motherboard
SOURCE: nvidia geforce 9400gt 1gb card problem
The maximum performance of your video card is limited by the hardware you attach it to. In the display properties of Windows, your highest resolution is 1280x1024 because your monitor is not able to go any higher than this. This resolution is a typical maximum for a 17" monitor. Some 15" can do this, and some 19" can do this. In order to get a higher resolution, you'll need to get a bigger monitor with a higher native resolution. For example, a nice 24" monitor can only do 1920x1200. The video card can go higher, but it's limited by the monitor. 32bit color is your highest setting - that's 16 million colors. Your video card's 1GB of RAM only determines how much rendered data (usually 3D) it can store and move at any given moment, which is related to but not determined by your screen resolution. That's a very nice card - you should be able to get very good frame rates, color, and performance out of 32bit color and 1280x1024. If you want a higher resolution, you'll need to get a bigger monitor.
