Question about Archos 504 500870 Digital Media Player
Archos 504 charging
I have just got a 504 and am still learning about it. My question is, when i charge it up from USB cable the unit automatically powers up, so its charging but also running This obviously is not doing a good charge up.If i keep pressure on the power button then it all shuts down even the charge light. Is there a way to charge but for the unit not to power up ?
Just for mat it . its the best way to recover it
Posted on Oct 18, 2007
6ya staff
SOURCE:
I am not able to connect my achos to my pc or laptop. When I attached the cable from my achos to my system; it charges the battery but I cant access the hard drive and other files
If you plug the Archos when it is off, wait until main screen appears, press OK button when the message about charging pops up, then press MENu and scroll down to the USB options, select hard drive mode. Please read the manual you can download at Archos official site/support/downloads
Apr 05, 2010 | Archos 504 500870 Digital Media Player
My archos 504 will not charge the battery . how much is a new battery
You can get one in www.newmp3technology.com for 22€ aprox.They are Archos providers,and the large life of their batteries are well tested.
Feb 05, 2010 | Archos 504 500870 Digital Media Player
My archos 504 wont charge when i connect to my computer
The Archos need to be plugged into an "active" USB port, giving 5volts and no less than 500mA. Some old computers or laptops couldĀ“nt reach this performance.
Feb 02, 2010 | Archos 504 500870 Digital Media Player
Unit crashes then will not restart after being unresponsive.
After removing the battery, I discovered a small brass reset button, about 3 mm in diameter, near the battery connection terminal. This was gently pressed with a pen for 15 seconds. After refitting the battery, the unit was fully functional again. This reset results in needing to set the clock again. No other settings are affected.
Jan 08, 2010 | Archos 504 500870 Digital Media Player
Charging for 30 hours so far...
mine seemed to take ages on the first charge but after like 3 days or so the light started to blink.
Aug 26, 2009 | Archos Internet Media Tablet MP3 Player
Archos 504 comes on when plugged in briefly but no charge
I had the exact same problem, I looked a bit on the net and I found the answer. What you have to do is push the reset button when your archos isn't plugged on. The reset button is located behind the battery ( you'll have to the remove the battery ) near the pins that connects the archos to its battery. It looks like a gold circle and if you push it you'll see it's a button. After pushing the reset button try to put the battery on back again and replug your archos, it should work normally now.
Good luck !
May 12, 2009 | Archos 504 500870 Digital Media Player
Loose USB connector, Archos 504
There is nowhere, except in Philadelphia - and they will charge you as much or more than Archos. Mp3 players do not have economical repair services.
Jun 26, 2008 | Archos 504 500870 Digital Media Player
Archos 504 Powers Up and Immediately Shuts Down!
bad battery bad ones will show charged but cant push out full violts pc needs ok buy new one 1st
Jan 28, 2008 | Archos 504 500870 Digital Media Player
Archos 504 500870 Digital Media Player Logo
140 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
 Mike M
Mike M
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
