Forgot iPhone passcode or iPad passcode? This can be fixed with iTunes actually.
Connect your iPhone to your computer.
In iTunes, select the iPhone in the "Devices" list, then "Summary" at the top of the screen. If iTunes doesn't automatically synchronize your iPhone, do so manually
Click "Check for Update." iTunes tells you if there is a newer version of the iPhone software available.
Click Restore. Follow the onscreen instructions to complete the restore process. When restoring, it is recommended that you backup the iPhone when prompted.
When iOS Setup Assistant asks to set up your iPhone, choose "Restore from iTunes backup."
Select your device in iTunes and choose the most recent backup of your iPhone.
http://www.transfer-iphone-recovery.com/forgot-iphone-passcode.html
If you have iTunes/iCloud backup, it would be easy to restore your iPad. You can just follow below steps.
1. How to Restore iPad from iTunes Backup
1. Plug iPad into computer via the USB cable. iTunes will launch, if not, manually open it on your computer.
2. Click "File > Device > Restore from Backup" at the upper right corner of the iTunes window. Or right-click the name of your iPad which shows in the left sidebar. Then choose the iPad backup you have created on this computer.
3. iTunes will start restoring your iPhone. Sometimes it will need your Apple ID to start working.
2. How to Restore from iCloud Backup
1. Tap Settings > General > Reset > Erase All Content and Settings on your iPhone.
2. iOS Setup Assistant will guide you to select languages and so on.
3. Tap "Restore from iCloud Backup" when the iOS Setup Assistant asks you to set up your iPhone.
4. Enter your Apple ID to start restoring iPhone from backup.
Note that in the first step of restoring iPhone from iCloud backup, you will be required to erase all the current settings and content in your iPhone, and if your non-purchased items are not saved on your computer, they will be gone for good.
For more details, check: Two Methods to Restore iPad from Backup
Actually,don't be too worry,if you have ever synced your iPod, iPad, iPhone with iTunes on computer, Coolmuster Backup Extractor is a good choice can help you recover lost or deleted iPod, iPad, iPhone data from iTunes Backup files. It offers you the fast & simple-to-use way to extract and recover your data such as photo, video, camera roll, voicemail, Message, contact, note, calendar event, call history, voice memo, Safari bookmark and App Data etc from iTunes Backup. Easy to use software and no technical knowledge required.
SOURCE: Unable to access some apps installed on my iPad because no icon shows up on the iPad for these apps
When you exceed your allowed pages for apps,they will still install,but app cannot be created for lack of pages.You can get more room by grouping similar apps into 1 folder to make space.You can also use search function to fill any app installed.Scroll all pages to right until keyboard appears,then type name of app,it will appear in dropdown list.
Please Rate
Be sure that hard reset retains all data and settings on iPad, it doesn't delete anything. If you want to start over and delete all personal data from iPad you should use iPad Recovery Mode.
