SOURCE: smart failure predicted on hard disk 4
Yes usually that error means that the hard drive is telling the controller card that there are some problems with the drive.
Although the drive may still work, it is highly recommended to replace it with a new drive.
I would replace the drive but keep the old drive just in case, after re-installing Vista you find that there is additional data you did not backup or remember to backup.
Just replace the drive, and if it's a Dell laptop, use the Dell Vista reinstallation DVD, and it will not ask for a keycode to reinstall.
May also want to go to another computer and go to support.dell.com and click Drivers and Downloads. Type the service tag and go ahead and download all drivers needed (i.e. network card, sound card, etc.) so after you reinstall Vista, if there are any drivers missing you will be ready to install them.
Hope this helps.
SOURCE: Smart Failure Predicted on Hard Disk 4
Are you sure you don't have a usb or other device plugged into your computer. Your main hard drive should be disc 0. Disc 4 is usually a disc further down the line, like an external or something like that. If it indeed the case then you may be having a problem with the boot in your primary drive. Try booting the disc with a windows installation disc. load the dosc and boot, when it says so, hit any key to boot off cd. When windows loads, hit repair this installation. It will reboot when it is ready. If that doesn't take care of it, reload the disc again and try to restore the drive to an earlier time, like a day or two ago. If this doesn't work, you may have to get another hard drive and reload the system. Don't get rod of the other hard drive though because you may still be able to access the personal files off of it as long as it hasn't had a mechanical or electrical problem keeping it from spinning.
SOURCE: SMART Failure predicted on Hard
The Harddisk is Bad - You need to replace it
Take a backup of Your Personal Data
