You have the alternativa to fold the treadmills, and get help for another persons. Please see the user manual from Life Fitness, and see the section how to fold the treadmill, and ready.
If you do not have the manual, go www.lifefitness.com see the customer service, go parts&manual, give you model and download for free. or to www. searsparts.com
I just requested and received the same from Silver Cross' having contacted them through their website. It wasn't listed in their manual section as it's no longer sold.
It won't let me attach it here though!
Do you know how to attach the Ventura Car Seat to the XT? It tells you in the manual how to remove the pram seat in order to 'attach the car seat' but stops at that! We have attachments marked L and R for the car seat and assume it rests on the grab bar facing you as if you were pushing the XT but cannot see where else it would attach as there is no room for the attachments to fit on to the side bars....
The position of the roof is determined by a pair of small electronic switches pushed up against a gear ajacent to the gear that drives the roof back and forth.
When "calibrating" the roof position to the logic (controller) You need to seperate the motor from the roof asy. command it wide open, then manually slide your roof open. Once close, use a flat-head scrwedriver to push the cords where the gear normally would the rest of the way to the alignment marks.
This is located near the back of the track, the two silver hatch marks on the plastic tilt slide should be just behind the track opening if I'm remembering correctly.
Once everything is lined up, it should work great. If your off by a tooth or two, pull the motor, and move it with the scewdriver, and try again.
Pull down interior design near button, it's all velcro underneath. The motor is silver and on the bottom of it, there is a white colored knob, that has a slot for a screwdriver. I believe to close it is counterclockwise. For this you will need VERY small screwdriver, and requires much force with a small one.
I poked a hole through the interior, and used a longer screwdriver. More torque and less pain on hands. Poking a hole sounds weird, but to be honest, it won't be noticed much.
