SOURCE: Hotpoint CTD00 trips the power
This happened to me.
Your condenser unit on the front bottom left corner may be clogged up and causing water to back up around the fan and heating element behind the rear panel.
Take condenser unit out and give it a good clean removing as much fluff as possible.
If the heating element senses damp on it, then it will trip the electric.
The back panel which is at 45 degree angle on back. I took this off and sure enough there was water in there.
Wipe away all water and use an ever so slightly damp cloth to remove as much dust stuck to the metal as possible.
I used a hair dryer for about ten minutes fanning over the heating element and circular fan. Don't rush this. Take your time to make sure all signs of damp have been removed from heating element before putting the back panel back on.
After carrying out the above my machine worked fine and no longered trip electric.
It is a pain, but to prevent this problem happening I suggest cleaning condenser unit about once a week if you have alot of washing. Empty water panel after every two loads, maximum.
Good luck
Jon
SOURCE: Beko tumble dryer not drying.
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
SOURCE: DRUM NOT TURNING ON BEKO TUMBLE DRYER. JUST OUT OF
Check your drum belt, sometimes this belt is broken or slipped off the motor pulley or idler arm pulley.
Also could be a faulty motor..
Another thing to try is to turn the drum by reaching inside of the drum and turning it by hand 1/4-1/2 turn with the dryer off. Then turn the dryer on again and see if it works.
Motors will sometimes get a dead zone in them and this help move it from the dead zone.
SOURCE: how do i change my tumble dryer belt on a beko
Just changed the belt on a Beko DRCS68W and its a real pig! Remove the top panel and loosen all screws on complete back panel having removed circlip holding the drum spline on to the back panel. You will also need to disconnect wires/leads on top right inside panel to give you more space. Once you have done this you should be able to ease away the back panel far enough to get the new belt around the drum and over the drum spline in the middle. Then the tricky bit - getting the belt tensioned on to the motor drive spline. I did this before securing the drum and back panel, which gives a bit more flexibility. I also used about 15ins of 15mm copper pipe to ease the belt down over the motor spline. Hard part was getting the back panel back lined up with the screw holes as the belt tension distorts the casing. Finally hit on the idea of lying the machine on its side so the weight of the drum is pulling away from the motor and helping to line up the screw holes. Two and a half hours later job done! I guess if I ever did another it would be a whole lot easier but still not the type of job I relish!
