SOURCE: Frigidaire FAH106N1 Thru-Wall/Window Air Conditioner
Check for blockage of the air pathway. Check that the fan turns freely, as the bearings or bushings could be shot. The fan blades could also be loose. You might just want to replace the fan, as it is cheaper than replacing bushing/bearings.
SOURCE: bought frigidaire AC. Says remove INTERNAL
that is the internal packaging they refer to, it should be a block of foam that is to be removed. You may have to take off the front cover to get to it.
SOURCE: my ac is not blowing cold air
The unit may be low on refrigerant. There is probably a low pressure switch in the unit to protect the compressor so it wont turn on and get damaged beyond repair. You can take it to your local appliance repair shop and have it looked at. I would get a quote on repair first. Most of the time it is cheaper to buy a new unit than it is to pay just the labor to have it repaired.
SOURCE: My AC unit is blowing moist, not cold air...
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
SOURCE: My Frigidaire FAX050S7A window mount a/c unit
Yes they can leak and will need a recharge....just check first that the leak is very small or can be fixed before spending the money to recharge it...with the low cost of window A/C units you can easily get a repair bill for more then a new one would cost...
heatman101
