Sony FD Trinitron WEGA KV-21CL10 21" TV Logo
R Tonui Posted on Sep 19, 2013
Why are green horizontal lines are appearing, too much yellow colour and green light blinking red?
Edward Carrington Vinton
Level 1:
Scholar:
New Friend:
  • Contributor 33 Answers
  • Posted on Oct 30, 2013
Contributor
Level 1:
Scholar:
New Friend:
Answers
33
Questions
0
Helped
4342
Points
60
These horizontal lines are vertical flyback lines and would indicate
one or more of the tubes cathode drive circuits are defective.
As the picture is predominantly yellow this would indicate excessive drive to red and green guns. Check the red and green video output stages especialy any clamping diodes.regards from Vintie
3 Related Answers
Anonymous
  • 668 Answers
  • Posted on Jun 17, 2009
SOURCE: 6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Anonymous
  • Posted on Jun 30, 2009
SOURCE: SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Anonymous
  • 86 Answers
  • Posted on Nov 17, 2009
SOURCE: Green and yellow images appear to be orange on the screen
hello my fellow electronics tech. it seems that you know something about electronics. i would check the color transistors on the circuit board on the back of the crt neck. i believe it is supposed to be around 5v per transistor. one way to be sure is to match voltages with the other two amps and see if the green has no voltage. you then make a resistance check. make sure all power is off and the voltage has been drained from the set. check the caps by the color ic also with an esr, or use your ohmmeter.test your color ic for correct voltages that could cause erratic color problems. thank you very much and please rate my solution
tip
Colour full BlackBerry ..If you are a Blackberry user.You must read this
In BlackBerry LED indicator blinks in different colors to deliver different notifications to the user:
Blinking RED: The LED indicator blinks red whenever you have incoming or waiting communication messages on your phone - new email, new call or missed
call,
Blinking GREEN: this is Coverage Indicator light. This lets you know you are connected to a network.
Blinking BLUE:If your phone is connected to a Bluetooth device, such as a Bluetooth headset it blinks blue.
Blinking YELLOW: A blinking yellow light means it is time to charge your BlackBerry
on Dec 15, 2009 • Cell Phones
Horizontal lines. Xerox 6505DN
clean the print heads and align them
My O2 Atom on normal mode binks in blue colour and there is a missed call or sms blinks in orange (or red). from yesterday it blinks in green on normal mode. Can you please tell me why? Anything wrong?
The notification lights indicate:
Blinking Blue - Bluetooth On
Blinking Yellow - WiFi On
Blinking Green - GSM (Phone) On
Blinking Red - Unread message
Continuous Red - Charging
Blinking green when your GSM (phone) is on is the expected behavior.
2helpful
Hi, im searching for the stereo wiring chart for my mitsubishi lancer 2002 GLXI. i have searched for it but the colours are completely different to what i have. For example the colours i have are - Blue/...
This is all I could find. Hope it helps.
WIRE COLOR POLARITY LOCATION
Battery RED/BLACK (+) RADIO HARNESS
Accesory BLUE (+) RADIO HARNESS
Ground BLACK (-) RADIO HARNESS
Illumination GREEN/WHITE (+) RADIO HARNESS
Power Antenna YELLOW (+) RADIO HARNESS
LF Speaker (+) WHITE/BLUE
LF Speaker (-) BLACK/BLUE
RF Speaker (+) WHITE/RED
RF Speaker (-) BLACK/RED
LR Speaker (+) YELLOW/BLUE
LR Speaker (-) GRAY/BLUE
RR Speaker (+) YELLOW/RED
RR Speaker (-) GRAY/RED
There is no yellow colour in my emp 7600, can you help me how to solve this problem
Yellow light is made up of red and green light.
Your projector has 3 LCD panels. You need green and red to make yellow.
go into the menu and check that all the colour values are reset back to standard.
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
A reflection light has appeared on the Sagem Axium HD-D45
Yes. A thin horizontal line that is always on red, green, blue, black or white is almost certainly a bad line in the display. If you purchased the display new, you should be able to get it replaced under warranty.
1/2" yellow line appearing in the middle of a background colored page
sounds like you need a replacement drum as it sounds like it is faulty, this is a replacable part and needs to ber replaced from time to time, this is a common symptom of this fault
Anyone know
Usually this occurs when the Convergence ICs go bad along with some chemical fuses mounted on the deflection board. E994 usually blows along with the Horizontal out transistor going bad. This transistor, I believe is Q777 that usually goes bad. The fuses are either tiny little yellow fuse with a red band or green with a yellow band depending on your model number
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
