Question about La Crosse Technology Wireless Forecast Station - Model WS-9133U-IT
Outdoor sensor not working, have reset according to La Crosse, changed batteries etc.
  • La Crosse Te... Master
  • 18,060 Answers
What is the problem? You said not working?
Posted on Sep 23, 2013
SOURCE:
My outdoor temp is slowing almost 10 degrees warmer than actual temp outside. What is problem.
You are using a wireless system that transmits signals between the outdoor sensor and the indoor receiver. They are not a perfect match. You cannot make adjustments, thus if your lucky, the factory matched up the devices prior to the sale. You may contact Lacrosse for a replacement outdoor temperature device.
Jan 11, 2018 | La Crosse Measuring Tools & Sensors
Changed batteries,now weatherstation does not receive outdoor imformation
La Crosse is very specific about what you should do and how you should do it for a battery replacement.
Begin by removing all batteries, both outdoor and indoor. Install new batteries in the outdoor unit. Allow the time it takes to get from the outside to the inside for the outside unit to initialize and begin sending data. Install batteries in the indoor unit and observe outdoor temperature. You should see indoor temperature as well. Finally, set the time. This last can be tricky as it seems difficult to set an exact time. I have two different La Crosse receivers connected to one transmitter and the one in front of me now is indicating 70 deg F indoors and 80 deg F outdoors.
Sep 11, 2016 | La Crosse Technology The Weather Channel...
Outdoor sensor won't work. Tried changing battery, no luck. Been trying this on and off for weeks. Any suggestions?
Some brands of Wireless thermometers need to have the base station reset to synchronize with the remote sensor. You would need to take the batteries out of both the remote sensor and the base station and then re-install all the batteries in both units (or three units if you have more than one remote sensor)
Each Manufacturer has their own procedure, La Crosse needs the procedure I described on many of their older systems. They may have changed it on the newer systems because I HATED resetting everything every time I change one set of batteries.
Feb 18, 2016 | Measuring Tools & Sensors
Why isn't outdoor temperature displayed on indoor unit?
I have a La Crosse unit right in front of me and it is showing +18 F tonight. Saturday, we are supposedly going to sub-zero.
With regard to your problem, La Crosse instructions are very specific about the battery replacement procedure. Remove all batteries from both units, then install new batteries in the outdoor unit. Allow time for the outdoor unit to "initialize" and begin sending temperature data. Install new batteries in the indoor unit and you should see the outdoor temperature displayed.
Feb 12, 2016 | La Crosse Technology Wireless Temperature...
La crosse support
Check the battery in the outside sensor. If the outdoor sensor is hard wired to the clock (or fresh batteries doesn't fix the issue) the unit needs to be replaced.
Jan 16, 2014 | Home
My outside temperature and humidity sensor appears to have failed. I'd like to buy a replacement. 433 MHz. The system is WS-7395U. Please advise price. taylor.norman1@gmail.
The WS-7395U uses the La Crosse TX8U outdoor temperature and humidity sensor. That part has a $49.99 MSRP. It is $46.95 from La Crosse; see http://www.lacrossetechnology.com/tx8/index.php to order the part. Other vendors that I checked do not have the sensor in stock for sale separately.
I hope this helps.
Aug 21, 2013 | La Crosse Technology La Crosse C86234...
Cannot get the outside temp to respond on a WS9047U-IT
Bring the outdoor sensor indoors. Take the batteries out of the sensor and out of the main unit. Wait 10 minutes. Put the batteries back in the outdoor sensor. Put the batteries back in the main unit. DO NOT PRESS ANY BUTTONS. Wait 10 minutes or until the outdoor temperature shows. Once the temperature shows you may use the buttons to set the clock, etc. If it does not show after 10 minutes, then try again.
Jan 07, 2011 | La Crosse Measuring Tools & Sensors
How do get the outside temp to work.
Bring the outdoor sensor inside. Take batteries out of both the sensor and the main unit. Wait 10 minutes. Put batteries in remote sensor. Then put batteries in main unit. Don't touch any of the buttons for 10 minutes or until the outdoor temperature is displayed. If still not displayed after 10 minutes then try again.
Dec 26, 2010 | La Crosse Technology Wireless Thermometer...
La Crosse Technology Wireless Forecast Station - Model WS-9133U-IT Logo
1,080 people viewed this question
Top La Crosse Technology Measuring Tools & Sensors Experts
ka4iup
ka4iup
Are you a La Crosse Technology Measuring Tool and Sensor Expert? Answer questions, earn points and help others
