SOURCE: Hello. I have a disney princess bed tent that my d...
I just put one of these up today with no instructions so I am going to share my experience. In my Disney bed tent there were two long sets of poles held together by an elastic string. 1) put these two sets of poles together. Now you should have two long poles. 2) Turn the three way brackets all the same direction on both long poles. 3) Lay out the tent and look in each corner of the tent for a little pocket to insert the end of a long pole...taking the other end insert into pocket, not diagonally, straight across the long way. 4) Do the same with the other side of the tent and long pole. 5) Now take your ten short poles and attach two together making 5 medium sized poles 6) Push these into the brackets along the long pole, kind of has a ladder effect. You are done!! I use mine with a full size blow up bed, the elastic gets stretched but I can set it up easily outside, or in the livingroom. Enjoy Nancy
SOURCE: i need assembly instructions for disney princess
Use the hardware that comes with
the Disney Princess canopy package to install the main canopy hook in
your ceiling. Center the steel ceiling hook above the center of the twin
bed and screw it into the ceiling by hand or with pliers. 2 Follow the included instructions
and insert the four poles into the sleeves of the canopy. The two
longer poles will run lengthwise above the bed, while the two shorter
pieces will run widthwise above the bed. 3 Attach the canopy to the ceiling
hook by slipping the plastic ring of the canopy onto the hook. The four
polyester sides of the canopy should now hang over the twin bed. 4 Use the customer support form through the Exxel Outdoors website if you have questions regarding your Disney Princess canopy.
