OVEN TURNS ON AND GETS WARM BUT WONT HEAT TO CORRECT TEMP. WAS TOLD I NEEDED A TEMP. GAUGE. PLEASE CONFIRM
SOURCE: Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
SOURCE: Estate Range #TE5400PXHQ0
MY SELFCLEANING WHIRLPOOL OVEN CLEANED ABOUT 30 MINUTES AND THEN STOPPED AND WENT INTO E2 AND F1. THE DOOR IS LOCKED AND WON'T OPEN. WE HAVE TRIED EVERY THING THE BOOK SAID AND NOTHING HELPS. DO YOU HAVE AN ANSWER?
SOURCE: whirlpool Electric range model RF386
I had the f5 code displaying on my range also. When I read your comment that power surges can do strange things, I just tried unplugging the range then plugging back in and it cleared the code.
Thank you Tory
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
SOURCE: Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
