Try dipping your finger in rubbing alcohol then, applying a little pressure, try to roll the ball around. This issue is common on these phone. Usually the pressure and alcohol help free any debris that may be causing the ball to stick. If that doesn't work the ball may need to be removed to clean out any debris that may be in there. A quick google search can show you how to remove the trackball easily.
Hope that helps.
