SOURCE: Wi-Fi Connectivity
login to http://xda-developers.com ;and this will solve the problem of your PDA
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
SOURCE: Windows Mobile 6 Won't Boot
bigsphinx, I too am having the exact same problem on both my phone and my wife's too, about once a month it just locks up then after a soft reset it just gets stuck on the green screen. I called support and they said I just have to do a hard reset, which loses everything :(
So for now I always backup (using PIMBackup) to my SD card for the next time it happens.
SOURCE: htc not turn on, red light on
Remove the battery from the mobile, press the power button, for 30 seconds.
Re attach the charger , switch on the phone. If it turns on switch it off again and reinsert the battery and check.
If none of the above steps work, you would have to take it in for repairs as there could be a problem with the power supply inside the phone , that would require special tools to open
Thanks
proton
SOURCE: "SOS" SIGNAL ON MY BLACBERRY RIM 8100 UNIT.
Try resetting the phone, firstly by powering down, removing the battery and powering back on.
