Coffee Makers & Espresso Machines Logo
berberi Posted on Sep 19, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change language from german french - Saeco Coffee Makers & Espresso Machines
Kolbrun Gunnarsdottir
Level 3:
  • Master 1,228 Answers
  • Posted on Sep 21, 2013
Master
Level 3:
Answers
1228
Questions
6
Helped
277367
Points
3915
The machines usually come with the language in the country they are bought in. You want to change the language. Once you are in the programming mode, press the up and/or down button until you come to language then press OK or equivalent. Then press up/ down until you come to the desired language and press OK. I hope this works for you, all the best Kolbrun
Change language i have brother mfc 9420cn in german language.need to change into english language. thanks
http://download.brother.com/welcome/doc002005/MFC-9420CN_UsaEngQsg_B.pdf
page 13 of pdf file
page 11 of document
Press Menu/Set.
2 Press 0.
3 Press 0.
4 Select your language (English or French) by using up or down arrows
press stop / exit
2answers
Which languages Kess V2( SE87) has?
KESS V2 can support English, French, Italian , Dutch ,Portuguese and Spanish.
3answers
I have a Casio TE-2400 and i need to change its language to spanish or french but i didn't find anything in the manual that came with the machine about changing the language ,So could you please help...
You can use English, French, Spanish, or German on this model, but you have to fully clear the machine and lose all settings because it can only be done at the start of programming. If this is a new machine out of the box, then no problem. If it has programming already, then you should back it up first. If you need the code, let me know
We have a grundig elegance tv and it has been changed to another language and cant get it back to english
If you can find the menu, look for a setting labeled with something LIKE: "idioma" (if it's been changed to spanish), "idiome" or "langue" (if changed to french) or "sprache" or "zunge" (if it was changed to german). Select this section and look for "ingles", "anglais" or "englisch". (These all mean "English" in spanish, french, and german, respectively.) Choose this and it should switch back to english. I hope this helps! Sincerely, Der Strom
3helpful
3answers
My camera in language problem please help me
I HAVE FUJIFILM CAMRA BUT WARE IS THE LANGUAGE CHANGE OPTION PLZ TELLL............
1helpful
In my fujifinepixf401 where is the option to on/off flash? and dere is no language changing option in this camera
Use the button next to the zoom button to cycle between flashmodes.
You can change language in the Set-up menu.
English, french or german is available.
2answers
Change languague from french to english in htc p4350
i have this problem is not change language for german to english please send me rom windows mobile english for htc p4350 is not quiet problem
please contact me : [email protected] or send me link for download software to formating mobile please kontakt me
3helpful
How can I change the language on my laptop?
If you just want to change the keyboard and general language settings, you simply go to the Start Menu -> Control Panel -> Regional/Language settings and change your language.
If your friend installed the Turkish version of WinXP (i.E. all the alert boxes are in Turkish) and you want to modify it to another language - that's a totally different and more complex situation.
In order to change the whole system language you can install a newer service pack in a different Language or uninstall the last installed Service Pack and after changing the registry settings below Install it again.
!!!Make always a backup of your Registry first !
You have XP SP2 in Turkish and want to change your systmes language to English, you will have to download SP3 in English (link).
(You can change the language here to another one before the download.)
Then you will have to change some registry keys. (Go to HKEY_LOCAL_MACHINESYSTEMControlSet001ControlNlsLanguage Registry Key), and change the value for “Default” and “InstallLanguage” from 041F (Turkish) to 0409 (English).
Reboot and you'll be able to install SP3 in English.
If no problems occur, you will have the whole system language changed.
Here is the List of numbers that represents each language in the registry:
* 0436 = "af;Afrikaans"
* 041C = "sq;Albanian"
* 0001 = "ar;Arabic"
* 0401 = "ar-sa;Arabic (Saudi Arabia)"
* 0801 = "ar-iq;Arabic (Iraq)"
* 0C01 = "ar-eg;Arabic (Egypt)"
* 1001 = "ar-ly;Arabic (Libya)"
* 1401 = "ar-dz;Arabic (Algeria)"
* 1801 = "ar-ma;Arabic (Morocco)"
* 1C01 = "ar-tn;Arabic (Tunisia)"
* 2001 = "ar-om;Arabic (Oman)"
* 2401 = "ar-ye;Arabic (Yemen)"
* 2801 = "ar-sy;Arabic (Syria)"
* 2C01 = "ar-jo;Arabic (Jordan)"
* 3001 = "ar-lb;Arabic (Lebanon)"
* 3401 = "ar-kw;Arabic (Kuwait)"
* 3801 = "ar-ae;Arabic (you.A.E.)"
* 3C01 = "ar-bh;Arabic (Bahrain)"
* 4001 = "ar-qa;Arabic (Qatar)"
* 042D = "eu;Basque"
* 0402 = "bg;Bulgarian"
* 0423 = "be;Belarusian"
* 0403 = "ca;Catalan"
* 0004 = "zh;Chinese"
* 0404 = "zh-tw;Chinese (Taiwan)"
* 0804 = "zh-cn;Chinese (China)"
* 0C04 = "zh-hk;Chinese (Hong Kong SAR)"
* 1004 = "zh-sg;Chinese (Singapore)"
* 041A = "hr;Croatian"
* 0405 = "cs;Czech"
* 0406 = "the;Danish"
* 0413 = "nl;Dutch (Netherlands)"
* 0813 = "nl-be;Dutch (Belgium)"
* 0009 = "en;English"
* 0409 = "en-us;English (United States)"
* 0809 = "en-gb;English (United Kingdom)"
* 0C09 = "en-au;English (Australia)"
* 1009 = "en-ca;English (Canada)"
* 1409 = "en-nz;English (New Zealand)"
* 1809 = "en-ie;English (Ireland)"
* 1C09 = "en-za;English (South Africa)"
* 2009 = "en-jm;English (Jamaica)"
* 2809 = "en-bz;English (Belize)"
* 2C09 = "en-tt;English (Trinidad)"
* 0425 = "et;Estonian"
* 0438 = "fo;Faeroese"
* 0429 = "fa;Farsi"
* 040B = "fi;Finnish"
* 040C = "fr;French (France)"
* 080C = "fr-be;French (Belgium)"
* 0C0C = "fr-ca;French (Canada)"
* 100C = "fr-ch;French (Switzerland)"
* 140C = "fr-lu;French (Luxembourg)"
* 043C = "gd;Gaelic"
* 0407 = "de;German (Germany)"
* 0807 = "de-ch;German (Switzerland)"
* 0C07 = "de-at;German (Austria)"
* 1007 = "de-lu;German (Luxembourg)"
* 1407 = "de-li;German (Liechtenstein)"
* 0408 = "el;Greek"
* 040D = "he;Hebrew"
* 0439 = "hi;Hindi"
* 040E = "hu;Hungarian"
* 040F = "is;Icelandic"
* 0421 = "in;Indonesian"
* 0410 = "it;Italian (Italy)"
* 0810 = "it-ch;Italian (Switzerland)"
* 0411 = "ja;Japanese"
* 0412 = "ko;Korean"
* 0426 = "lv;Latvian"
* 0427 = "lt;Lithuanian"
* 042F = "mk;FYRO Macedonian"
* 043E = "ms;Malay (Malaysia)"
* 043A = "mt;Maltese" 0414 = "no;Norwegian (Bokmal)"
* 0814 = "no;Norwegian (Nynorsk)"
* 0415 = "pl;Polish"
* 0416 = "pt-br;Portuguese (Brazil)"
* 0816 = "pt;Portuguese (Portugal)"
* 0417 = "rm;Rhaeto-Romanic"
* 0418 = "ro;Romanian"
* 0818 = "ro-mo;Romanian (Moldova)"
* 0419 = "ru;Russian"
* 0819 = "ru-mo;Russian (Moldova)"
* 0C1A = "sr;Serbian (Cyrillic)"
* 081A = "sr;Serbian (Latin)"
* 041B = "sk;Slovak"
* 0424 = "sl;Slovenian"
* 042E = "sb;Sorbian"
* 040A = "es;Spanish (Traditional Sort)"
* 080A = "es-mx;Spanish (Mexico)"
* 0C0A = "es;Spanish (International Sort)"
* 100A = "es-gt;Spanish (Guatemala)"
* 140A = "es-cr;Spanish (Costa Rica)"
* 180A = "es-pa;Spanish (Panama)"
* 1C0A = "es-do;Spanish (Dominican Republic)"
* 200A = "es-ve;Spanish (Venezuela)"
* 240A = "es-co;Spanish (Colombia)"
* 280A = "es-pe;Spanish (Peru)"
* 2C0A = "es-ar;Spanish (Argentina)"
* 300A = "es-ec;Spanish (Ecuador)"
* 340A = "es-cl;Spanish (Chile)"
* 380A = "es-uy;Spanish (Uruguay)"
* 3C0A = "es-py;Spanish (Paraguay)"
* 400A = "es-bo;Spanish (Bolivia)"
* 440A = "es-sv;Spanish (El Salvador)"
* 480A = "es-hn;Spanish (Honduras)"
* 4C0A = "es-ni;Spanish (Nicaragua)"
* 500A = "es-pr;Spanish (Puerto Rico)"
* 0430 = "sx;Sutu"
* 041D = "sv;Swedish"
* 081D = "sv-fi;Swedish (Finland)"
* 041E = "th;Thai"
* 0431 = "ts;Tsonga"
* 0432 = "tn;Tswana"
* 041F = "tr;Turkish"
* 0422 = "uk;Ukrainian"
* 0420 = "your;Urdu"
* 042A = "vi;Vietnamese"
* 0434 = "xh;Xhosa"
* 043D = "ji;Yiddish"
* 0435 = "zu;Zulu"
5helpful
2answers
Clicked the wrong language it is in French I want English how do I change it
Go to settings (usually a toolbox icon), select language, choose english.
Changing from german language to french language
You need to reflash ROM. Operation is a bit risky, if you don't follow the procedure. Consider upgrade to WM5/WM6.
All the information is on the  below Link -
http://wiki.xda-developers.com/index...=HTC_Blueangel
Remeber about fixing you keyboard layout in registry
Thanks
Top Saeco Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Sulejman Sulejmani
Sulejman Sulejmani
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
