I just bought a Sportline 241 a few days ago. It did not come with a instruction paper. Is there a site or some place I can download the instructions? I am having a lot of trouble trying to set it. I could really use some help please. Thank You, Avena Vigue
I just bought a Sportline 241 last week. The instructions are as follows. Note that there are no instructions for setting the 12/24 hour time option. Mine is in 24 hour mode (which is what I wanted), but I do not recall if it arrived that way or if I stumbled onto this mode when setting the time/date or alarm functions.
I hope this helps.
SPORTLINE 241 WALKING ADVANTAGE KEYCHAIN STOPWATCH
FEATURES:
24 hour stopwatch
Time-of-day and calendar
Alarm clock
BATTERY:
Replace with LR41 battery
TO SET TIME AND CALENDAR:
From normal time display, press MODE button three times to enter Set Time/Date Mode. Seconds is automatically selected.
Press SPLIT/RESET button to cycle through minutes, hours, day, month, day of week, seconds.
Press START/STOP SET button to change digits on any of the above (seconds only: resets to 00).
Press and hold START/STOP SET button to advance digits rapidly.
Press MODE button once to return to normal time display.
From normal time display, press and hold START/STOP SET button to see the month, day, and day-of-week.
TO SET ALARM:
From normal time display, press MODE button twice to enter Set Alarm Mode. Hours is automatically selected.
Press SPLIT/RESET button to cycle through minutes and hours.
Press START/STOP SET button to change digits.
Press MODE button to return to normal time display.
From normal time display, press and hold SPLIT/RESET button to see the alarm time setting.
TO ARM/DISARM ALARM SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press START/STOP SET button to arm/disarm alarm sound.
Alarm will sound when indicator shows in upper right corner.
Release SPLIT/RESET button to return to normal time display.
TO ARM/DISARM HOURLY CHIME SOUND:
From normal time display, press and hold SPLIT/RESET button, then repeatedly press MODE button to arm/disarm hourly chime sound.
Chime will sound when dashes appear along top of display.
STOPWATCH OPERATION - GENERAL:
From normal time display, press MODE button once to reach stopwatch timer display.
After use of any stopwatch feature, press MODE button once to return to normal time display.
START-STOP (TIME-IN/TIME-OUT) TIMING:
With stopwatch timer on display, repeatedly press START/STOP SET button to start or stop the timer. When timer is stopped, press SPLIT/RESET button to reset timer to 0.
SPLIT TIMING:
With stopwatch timer on display, start the timer with START/STOP SET button. Repeatedly press SPLIT/RESET button to split or release the timer. Press START/STOP SET button to stop the timer. Press SPLIT/RESET button to reset timer to 0.
1-2 FAST FINISH:
Press SPLIT/RESET button for STOP #1.
Press START/STOP SET button for STOP #2. The stop time for #1 will now be shown.
Press SPLIT/RESET button. The stop time for #2 will now be shown.
Press SPLIT/RESET button to reset the timer to 0.
I've been using my Sportline 241 and I discovered a feature not documented in the instructions -- mine has a 5-minute snooze alarm feature. So for my watch, I amend the above instructions as follows:
1. To disable alarm feature from sounding daily. From normal time display, press and hold the SPLIT/RESET button, then press the START/STOP SET button TWICE, or until alarm symbol is no longer shown (upper right corner).
2. To dismiss daily alarm sound, and alarm remains armed. From normal time display (while alarm is sounding), press and hold SPLIT/RESET button, then press START/STOP SET button ONCE. Daily alarm is dismissed, and alarm remains armed for following day (alarm symbol is still visible in upper right corner).
3. To silence alarm and engage snooze feature. From normal time display (while alarm is sounding), press START/STOP SET button once. Alarm will sound again in 5 minutes, and repeat every 5 minutes for one hour or until dismissed.
Hi: Just found this while looking for instructions on how to disable hourly chime/alarm clock on my Constant LGA103/C and can confrim that these instructions also work for that watch. Thanks for uploading!
Thank you for the link. It helped with some other problems but not the one I need. I have a stopwatch/clock and the site didn't have any of them.
Thanks,
Avena Vigue
