Question about Honda Garden
Honda p/washer won't **** up cleaning chemicals cleaned filter,still no go.
    President:
  • 389 Answers
In general, pressure washers will draw detergent from the reservoir only when the spray nozzle is set to low pressure. At high pressure a non-return valve closes to prevent water flowing back in to the reservoir. If you've got the spray nozzle set to low pressure and still have the problem, it may be that the spray nozzle is partially blocked - you can try clearing it with a length of wire.  Failing that, the non-return valve is probably stuck (and that may need professional attention).
Posted on Apr 18, 2009
SOURCE:
LG Tromm WM2233HW- Problem with oily residue on clothes
Use warm water and powdered detergent. Leave the door open in between cycles and it will be clean as a whistle in a week... Powdered detergent is HE also, don't believe the hype, stop wasting your money on useless chemicals to rinse away the garbage chemical soaps you are being ripped-off by... Hopefully, the liquid detergent hasn't corroded the washtub and drive shaft so badly it is oozing slime!
Jul 26, 2016 | LG Washing Machines
Gcv160
Clean it up real well and try again. Most likely the oil is from the motor being put in a position that allows the oil to run into spots that it is not supposed to be in.
May 17, 2013 | Honda Black Max 2600 PSI Pressure Washer
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
The chemical injection system on my craftsman 2500psi washer will not inject cleaner through the wand. have cleaned all parts and still won't work
The chemical injection system works by siphon action. You must have the black or largest/ low pressure tip installed for it to work properly. If you feel any pressure at the wand, most likely will not work. If your wand has the adjustable type tip, it may have a restriction causing pressure and not allowing siphon action. If you continue having trouble with siphon, you could plug/shut of siphon and install an aftermarket injector between the wand and the pump (not expensive). Sold at www.pwmall.com Good luck
Jul 01, 2011 | Karcher 2500 PSI Pressure Washer
Craftsman Pressure Washer 580.752160 reagent/chemical not being dispensed when wand in low pressure position.
It is very common for the chemical injector valve on these to get gummed up from residual soap sitting in the valve. To clean it follow the chemical hose back to where it attaches to the pump. There will be a hex headed hose barb attached to it. Remove the barb from the pump. Underneath it you will find a spring and a ball bearing. Rinse the parts thoroughly and reassemble. You should also check the chemical strainer that goes into your chemical bucket. They can also become clogged and should periodically be cleaned.
Sincerely,
Aron Kerr
Landa Northwest, Inc.
www.landanw.com
Mar 07, 2011 | Craftsman 2700 Max Psi Pressure Washer 23...
Black bits in carburetter
Either dirt in the tank is getting into the carb or the fuel line is deteriorating and pieces of the inside of the line are getting in the bowl. Disassemble the petcock and replace o-ring, screen, and four hole washer. Put on a new fuel line and consider adding a small inline filter typically used on a lawn mower. This should even take care of rust that may have formed in the tank over the years. If you have bad rust in your fuel tank a chemical cleaning kit can be purchased to soak the inside of the tank and clean out the problem.
Aug 04, 2010 | 1970 Honda CB 100
Genrac power washer chemical injector not working
How long is your high pressure hose and what diameter as it maybe to long and won,t **** chemical due to back pressure. To test this remove the high pressure hose and run the machine and check too see if any chemical is coming up the pipe. If it does then its a problem with your hose or the adjuster is not going to low enough pressure.
Jun 04, 2010 | Garden
Just bought a used karcher hds 500ci every now & again lots of smoke belches out burner is this a bad sign ? also cant seem to get the chemicals to pick up any tips
you burner assy needs to be cleaned , spark electrodes properly gapped and the fuel pump pressure set , the chemical pick up often gets clogged , and the chemical valve ( pump side becomes jammed ( a small ball bearing jams in the seat )
also clean out the diesel tank and clean or replace the fuel filter , if the smokes is white thats caused by water in the fuel , black smoke is too much fuel going to the burner assy or your ignition electrodes not igniting it
Nov 15, 2009 | Garden
Chemicals left behind in washer
i honestly would check with the manufacture of the chemical, with out knowing whats in it how do you know how to clean it?
Dec 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Garden Logo
260 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
