SOURCE: I would like to know where the fuse is located for
There are 3 fuse boxes called s.a.m,s one on each side of the engine compartment and one under the rear seat cushion under the plastic cover on the carpet. The vehicle has a hidden fuse schematic either under the plastic cover on the l.f. of the dash accessible by opening driver's door or in the trunk in the took kit or possibly under one of the side panels in the trunk. They hide them in various places in different models. I hope I have been helpful
SOURCE: radio and cigarette lighter not working 1991 mercedes 190e
Spin or replace the fuse as the old aluminum fuses build up corrosion and dont work, or work on and off.
If its an after market radio check by removing unit and checking for fuses in line.
SOURCE: where is the fuse box for the cigarette lighter in
look under the hood for a black box most likely on the passengers side ..you may need a screwdriver to remove the hold down bolt ...other models depending are in the glove box behind a panel {accessible } as yet others are on the door dash
Testimonial: "Many thanks. I am most grateful."
SOURCE: where is the fuse for cigarette lighter. fuse
Hi! The cigarette fuse is somehow interconnected with the radio fuse. If no luck, then i believe that the cigarette lighter needs to be replaced. Hope this helps and have a good one!
SOURCE: Neither cigarette lighter in my
LOOK IN OWNERS MANUAL IN GLOVE COMPARTMENT.IT HAS ALL FUSE AND RELAYS LOCATIONS.
