Televison & Video Logo
Posted on Apr 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I trying to control the cable box for my tv with remote model number bn59-00695a, the tv is a ln40a650a1f
Anthony Gonzales
Level 2:
Sergeant:
Champion:
  • Expert 267 Answers
  • Posted on Apr 24, 2009
Anthony Gonzales
Expert
Level 2:
Sergeant:
Champion:
Answers
267
Questions
Helped
85625
Points
536
See the oners manuel for the code to operate the cable box or go online to the manufactures website and down load the owners manuel
Our remote bit the dust in the hurricane in Bonita. Can we get a replacement? Model 0625615? Thank you!
Hello, Nina -
Clarification: Are you asking about a replacement remote control for your TV or for your TV cable or satellite box?
If it is the remote control for the TV, you can purchase a universal remote control which should work with your TV. Be sure to read through the manual which comes with the universal remote control.
If it is the remote control for your TV cable / satellite box, then you should be able to call the Customer Service number for the cable / satellite provider and ask for a replacement remote control. You will probably need to provide your cable or satellite customer number and maybe some other form of ID.
RCA TV Converter Box DTA800B1. Codes for roku tv
For a Cablevision cable Provider the remote controller Model Number is UR2-CBL-CV04 and its remote device unique codes for Roku TV become 031, 081. To get a Charter Cable Provider the remote control Model Number is usually UR4U-MDVR-CHD2 and its remote control codes for Roku TV be 11756, 11602. The user on find their respective remote controller code, have to activate their Roku account using enter Roku activate code to get started on streaming their recommended shows.
For a new Cox Communications Cable Provider the remote control Model Number is URC-8820-MOTO and its remote control codes for Roku TV be 1756, 2360. For the DirecTV Cable Provider the particular remote control Model Number will be RC65 and its remote control codes for Roku TV be 11756, 10818. For a Dish Network Cable provider the handheld remote control Model Number is 21.1 IR/UHF and its remote control codes for Roku TV be 535, 556.
The ONN Cable Supplier the remote control Type Number is ONA12AV058 in addition to its remote control rules for Roku TV are 3851, 3201. Once the consumers remote controller are programmed with the respective codes then the user also have to activate their Roku accounts using enter Roku activate code to start out enjoying their preferred streams.
Hope you find your own appropriate code for your cable providers. For any help on adding the RCA Roku TV codes call our technical support staff members through toll-free numbers +1-855-804-1313 or visit them at roku.com/link
Set motorola dch6200 remote control
You're probably better off programming the cable box remote to control your TV. Samsung codes are standardized, Motorola not so much.
My remote controls the volume via the cable box, how can I make it control the tv volume?
you have to program in the code into remote for your tv brand. goto this website and select your model number http://www.sciatl.com/ExplorerClubGuides/getting_started.htm
The Audiovox Rca RCRN04GR Universal Remote Control
Try to Google the model numbers of each for "manual" to see if available.
We have a universal remote control for a t.v. with a cable box and we are trying to program it to a samsung t.v. but we cant find the code.. we lost the piece of paper with the codes and the instruction...
No one can give you a well-defined answer since that would require brand names and model numbers of all devices. If the remote is more than a year or two older than the TV or cable box, it may not have any useful codes available. I suggest you get all the pertinent names and model numbers and try remotes.com The cable box maker may also have information you need so go to their website.
I have a small elemet tv with a en21645e remote control. My grandson did something to the remote and now I only get the local channels not cable channels although I have cable hookup
The little tyke has most likely pressed the INPUT button on the remote control and switched the TV away from the external input setting required for watching cable TV.
You did not state the model number of the TV and some TVs function differently with regard to the selection of external inputs, but you should be able to return to watching cable by pressing the INPUT button slowly but repeatedly until you can see the picture from the cable channels again. The INPUT button is located in the top right corner of your Element remote.
If an input selection menu appears on screen when you first press the menu button, use the arrow keys to highlight another input, then press ENTER to select it. I can't tell you which will be the correct input as I don't know the model number of the TV and it depends on which type of cable you are using to connect the TV to the cable box. You should try each input in turn until you are able to see the cable channels again. Please make sure the cable box is switched on when doing this!
If you are still having difficulty, please reply to me from within this page with the model number of the TV and the type of cable you are using to connect the cable box to the TV. I will then be able to provide exact instructions for switching your TV back to the cable input.
Hope this helps.
Regards,
BElectric
Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
2answers
Want to use cable remote 4 tv as well
reade the booklet that came with the cable box to get the program #'s for the remote to control you tv as well
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
