02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Won't be an inexpensive fix...good luck
SOURCE: My plotter is saying that
The printer is having a problem finding the Scan-axis encoder reading.
Start by upgrading the firmware. Go to www.hp.com. Go to Support and Drivers.
Enter your printer model, select your operating system, select firmware.
Follow the directions.
If that doesn't fix the problem, clean the encoder strip( the flat metal strip that runs the length of the printer).
If the problem persists, someone trained on DesignJets is going to have to look at it.
Hopefully, the firmware will fix the problem.
SOURCE: error code 22.1:10 on HP Designjet T610
HP does not specify what that error means. It says to contact HP Support. If the unit is in warranty, Hp will repair it, free of charge.
HP and Compaq products
800-HP invent
or
800-474-6836
24 hours a day, 7 days a week for most products
U.S.: English and Spanish for most products.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Hi, In the office we
It is a PPS system failure(Pen to Paper Space).
Turn power off and pull the plug from the wall outlet.
Reconnect and power on.
In the Diagnostics perform the Scan Axis PRS diag test.
If it still fails a tech is going to have to look at it.
Sorry, but this may need parts replaced. A print mech board or the PPS solenoid.
SOURCE: hp dnj t610 plotter 79:04
79.04 is a generic software error.
Can be caused by bad firmware.
Can be caused by bad job.
Try sending a different job to the printer.
If that works and the original job fails again, something is wrong with it.
If the new job fails, power off and on again. Resend the job. If it fails again...go to
www.hp.com. Select support and drivers. Upload the latest firmware.
This one isn't easy. Good Luck
