By mistake - I have deleted some important records from access mdb file. Can these records be undeleted ? If yes how ? Please Help ...
Ou can try to use third party Access recovery utility to restore your lost and damaged data from .mdb files. For more details about this software:-
Access File Recovery
Accidentally deleted, damaged by viruses, crashed of system errors MS Access files you can also retrieve owing to access database fix. It makes all process in your some simply steps due to clear, intuitive recovery wizard.
Smart solution to recover the full Access database.Using this application you can smoothly recover your lost MDB or ACCDB files.
Go to:- QuickBooks File Recovery
Access file recovery software is an affordable or efficetive tool. It can easily repair and recover from damaged MDB/ACCDB files without any hassles. Reference link:- The software also available free trial demo version : Access File Recovery
Unfortunately not unless you made a backup. Access is very unforgiving. Not Like excel where you can undo your mistakes multiple times. Be very carefull when deleting. Try to make copies to workwith first.
You can go to this link and try it out. Make sure you make a backup of your database first.
http://3d2f.com/programs/66-941-recover-...
This is mainly for recovering corrupt tables/databases, but it claims to be able to recover deleted records also. If you give it a try, let me know how it works os I can post it to help other problems.
Quickly get back corrupt access database files once again while using PDS MS Access File Recovery software. Advance MDB repair tool recover access files with all table structure, table data, key fields, primary key/foreign key, auto inrement, field size, exact date & time and many more.
Read more:-
Access File Recovery Software
Recover Access file and tables due to following application http://www.accessrepairtool.org . It must assist you to restore Access file any version of MS Access program. Also read this post http://diskdatarecovery.jimdo.com/2011/11/30/resolving-disk-i-0-error-during-read-while-working-with-ms-access
so there is noway out ..... thanks anyways ....
