SOURCE: hardreset motorola mb508
To reset your phone,Please follow this procedure
1. Open the Application tray
2. Touch settings
3. Scroll down and touch policy
4. Scroll down and touch Factory Data reset
5. Touch Reset phone
If you can not access the menu,Here's the Hard Reset method
1. Power of your mobile
2. On the hardware keyboard,Hold the "X" key and the "Power" button.
3. When Moto symbols comes out,you may now release the "Power on" key but keep holding the X key until you see a triangle and an exclamation point.
4. Now press the "Fn" key and "T" key at the same time.
5.You will now see a menu on screen
6. use keyboard cursor key to move the blue highlighted selections
7. To proceed, select "Wipe data/Factory reset
8. press the return key to select the option that is highlighted.
9. Use the cursor key to highlight YES from the next menu.
10. Press the return key to complete the selection.
11. reset is on progress then wait until it's DONE.
12. After the process,you will see a message "Reboot System Now",select it using the cursor.
13. Press the return key to reboot the device.
Thank you for visiting Fixya...
SOURCE: Unlock att motorola blur mb508
Unlock Cell Phones
Your cell phone may be locked to a particular cell phoneprovider and in this case it needs to be unlocked to use with a different cellphone service provider.To get the security code/restriction code to unlock the cellphone from the current cell phone provider so you can use the SIM card with adifferent phone provider, Please click on this link and follow my instructions:-http://www.fixya.com/support/r4049238-unlock_cell_phoneIf yourphone provider does not help you then these WEB sites it provides securitycodes for a small price.http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHwhttp://www.mobileunlocksolutions.com/http://www.superunlockcodes.comhttp://unlockcellphonecode.com/
The first is you must have a SIM card that is configured with the correct data plan and set up a MOTOBLUR account to gain access to your phone. To create MOTOBLUR account can only be done from the phone.
Now you can create a new account in MOTOBLUR wit:
Then you can set up your account. For the first time you login to your account, better you do:
If you love manual work, you can import contact manually from SIM card with:
Some time you don't need the MOTOBLUR account and want to delete it, you should contact your Motorola Call Center to request for your MOTOBLUR account be deleted.
