NEED THE 4- DIGIT CODE FOR THE TV . ARE NOT ALLOWED TO USE REMOTE CONTROL.
SOURCE: toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
SOURCE: Need remote control code
you need to use the dvd codes that are given (20695) and program it under auxilary mode.
SOURCE: lost four digit code
Ok here are the master codes for Toshiba, One of these will work for you.
Toshiba 0 1 5 4 ,0 1 5 6 ,0 0 6 0 ,1 2 5 6
Kindly rate my help++++Thankis for using FIXYA
SOURCE: need the 4 digit universal remote control code for
your user manual for tv should have that in it. however go to www.manualsonline.com enter the universal remote mfg and model number in search bar, if they have it there, you can download the manual w/codes for free... best of luck.
