I can only be these causes.
1: hdd bad.
2: it's telling you the truth, the restore partition is corrupted,
takes way more than simple file names, there.
3: someone used microsoft disks or others, an attempted to install other OS, and wreck this partition structures and files.
the cure is same, HP media kit. (posted 100000 time at hp,)
For a factory reset there are two installation options: C:\ drive recovery System recovery
System
recovery will rebuild the partition. C drive recovery will simply re
install the C drive on the active partition. When you do full system
recovery we create a hidden partition that is read only. this gives you
the F10 boot-able recovery partition tools.hit f-10 on boot up
using hidden partition
hold F9 during bootup (requires recovery partition)if you have installed windows XP to your
Eee PC , the hidden partition would be cleared and cannot be used for system recovery.
Maybe your inspiron 1525 battery need to clear all the Dummy File and cookies and virus. Then close all the neednot program. If this cant solve the problem, it must be the hardware problem. Send the laptop to dell customer to ask them repair it
This is talking about your Recovery Partition which is D: and your Local Disk is C: most likely. You can see and review these partitions by doing this:
Start-> Run -> diskmgmt.msc [enter]
To make some room on this Recovery Partition do this:
Start-> Run -> D:\ [enter]
See if there are any file that might have been placed there on accident and remove.
Hi, Please go to Start + Run and type cmd Type chkdsk d: /F /X /R It will dismount and check for any errors after the system restarts follow the method to clean the disk space. ) Open
Internet Explorer and click on Tools
2) Click on Internet Options
3) On the General Tab, in the middle of the screen,
click on Delete Files
4) You may also want to check the box "Delete all
offline content"
5) Click on OK and wait for the hourglass icon to
stop after it deletes the temporary internet files
6) You can now click on Delete Cookies and click OK
to delete cookies that websites have placed on your hard drive.
To clear
the Internet History in IE:
1) Open
click on Clear History
4) Click OK
To clean
up other temporary files on your computer in Windows 98
or higher:
1) Click
Start, Programs (or All Programs), Accessories,
System Tools, Disk Cleanup
2) Choose the correct drive usually C:\
3) Check the boxes in the list and delete the files
It sounds like you have been storing files on the Recovery partition (D:) instead of your C: drive. You should not do that. The Recovery partition should just that. If you need more space consider a USB external hard drive.
