Question about Canon imageRunner C3100 Copier
Canon IR C3100n copier "NG 853" error
I cannot make this copier print through the network connection. I can see the unit from Windows and I have connectiov (verified using the PING command on the copier and Windows). However, the network device receives the job, but is automatically posted on the log as "NG #853 error".
  • 1 more comment
  • Felix Lopez
    Felix Lopez Sep 21, 2007
    Just found what was happening. Install the unit under Windows stating manual print selection and choose "Canon printing device L9100" when asked for. Although the unit can be set to accept LPR or RAW print formats, I solved the issue with the RAW format. But be advised, changing the specification for an installed driver does not work. You will have to assign a new IP address to the unit and start the driver installation from the beggining.
  • Anonymous Dec 17, 2008
    I have this same error ng (#853) on a Canon iR2030. I deleted the printer, restarted the W2003 server, deleted the port, created the printer again, installed the driver, sent a print to it, log report on photocopier LCD screen shows status of OK, but nothing comes out of the photocopier!! Tried over and over again; the whole process; nothing. Absolute rubbish. Had enough and am going Xerox.
  • globalpro Feb 11, 2009
    print on computer, but doesnt come out on the printer. gives the error #853. i can see the printer connected to the network, i can scan, copy anything but print!!!!
    what to do???????
    New Friend:
I too tried the UFRv1.42_Win2k-XP-2003_INF Driver for the Canon C3100 and it worked superbly .
Posted on Mar 31, 2010
  • itdave71 Jan 26, 2011
    this worked for me too. Thank you!
    New Friend:
I had a similar problem with my MF6540. I could access the remote UI and see that the printer was recieving information via the print log. It would list all of my test pages that I tried to print but in the print results column I would get an error code NG(##5536) and the printer would not actually print anything. I tried the UFRII driver stated above and everything seems to be working now.
Posted on Mar 04, 2010
    New Friend:
  • 3 Answers
#853 is when you send a Postscript file (PS Print driver) to a PCL orUFR only printer driver device. PostScript on some products need the license to enable it, so Canon can pass your cash to Adobe for you using PostScript!
Posted on Jan 11, 2010
  • bnsibiya
    bnsibiya Jan 27, 2014
    the thing is, the rest of the other pc's on the network do print, except the 2 that i've just installed
    New Friend:
According to Canon rep I just spoke with you need to purchase a license before you can print to these. You cant just set them up as a network printer
Posted on Oct 23, 2009
  • shannon garrett Jul 11, 2011
    This is Correct, If this copier does not have a print option installed it will not print no matter how hard you try!
Just an update for ya. I don't know how it relates to network printing, unless it's due to the print driver configuration on the machine printing, but apparently (according to Canon) the NG #853 refers to insufficient memory resources for the printer. I only sent a Windows test page to the printer and still got that, so go figure... Anyway, gonna play around with the drivers and see if I can get it working. Will report back if there's any progress.
Posted on Sep 20, 2007
  • 59 Answers
Its a timeout for the data being sent, the ufr driver spools the job at the pc.
You can also try turning on network spooling in system settings, network, use spooler on
Posted on Nov 02, 2014
    New Friend:
I was having this problem with a Canon IR C3080 after I upgraded computers and started using Mac OSX 10.8. Previously, with my older system running 10.5, I had been able to print to the Canon with no problems. But since upgrading to 10.8, all the print jobs I sent to the Canon resulted in the #853 error code and with nothing printed. When setting up the printer on my new system, I had selected the Canon IR C3080/3480/3580 PS (US) driver that I had downloaded from the Canon website and installed into my OS. This is the driver that Canon specifies for Mac OSX 10.8. However, after re-setting up the printer, but selecting the Generic Postscript Printer driver (supplied by the OS), my print jobs were accepted by the Canon copier and printed as they should. So if a Generic PS printer driver is available to you, try it instead of the driver supplied by Canon.
Posted on Dec 11, 2012
  • Larry Thoman Dec 11, 2012
I had the same problem and installing the UFRII Driver for the printer did the trick.  There must be a memory management issue with Windows 2003 Server.  Next up, trying to get the scanner software working.
Posted on Oct 19, 2007
OK, this is not a solution, but we are having the same problem with an iR 3200. I've run packet captures and can see a TCP stream in both directions which indicates it's communicating, but the jobs keep getting the NG #853 error. The Get Status button within the driver properties fails to get anything from the printer, but when I try it, I can see udp traffic flowing in both directions between the server and the printer.
Posted on Sep 19, 2007
SOURCE:
Network intializing
see if the DHPC is enabled if so disable and give the IP address in copier. and ping in run command type: ping ip address space and -t to be entered to get reply.
May 13, 2014 | Toshiba E-STUDIO 450 Copier
Printer is offline
What type of printer are you having a problem with? Is it on and do you see any error messages on the printer? How is it connected to the computer? Do you have the driver installed? Some printers need to have the driver installed with a USB connection before moving to a network install. (For all-in-ones, the driver/software must be installed before you connect the data cable.)
If a wired connection, try new cables (fully seated) and different ports. If it is a USB connection, try a direct connection if the printer is connected to a USB hub or print server. Make sure that the cord is 6' or shorter. Check if other devices work. (I've seen a few computers loose their USB ports for no apparent reason. On desktops, try rebooting the computer and uninstalling the USB drivers and rebooting again. This is in the Device Manager for Windows machines. On a few laptops, sometimes removing the battery and the power adapter will reset the ports.)
For network connections, make sure that your network is up and that you aren't getting signal loss issues (for wireless networks). Try a wired connection to check for network loss. To check a network, I tend to check a few points with the ping command. For Windows, launch the Command prompt and ping the numerical IP location of your router. Then ping the IP location of the DNS server. Can you see the printer on your list of network places. (The format for ping is
ping 192.168.1.1 or ping www.google.com followed by enter. The returned message will be either the time for a small packet of data to go to the location and return or a connection timed out.)
If you are losing your network connection, reboot your router and broadband modem. (Try rebooting the router first.) Make sure your firewall is not blocking access to the printer.
I hope this helps. Please write back for more information with specifics for your printer.
Feb 12, 2011 | Office Equipment & Supplies
Vista to Vista wireless, Can't share printer
So your third laptop which runs Vista cannot connect to the Printer and Dell machine?
There are some reasons for that. First check whether you have access to the Dell machine (whether you can reach it) Open a command prompt and do a ping to verify the connectivity. Example. ping 192.168.1.2 (The ip address should be the one of your dell machine. You can find it by running ipconfig in a command prompt on Dell machine.)
1. If you cannot reach it you have to check the network utility (wifi or any other method you use). Make sure that it function properly. 2. ping the router using router's ip address. If ping works you can reach up to their. So from there you can check the Lynksys management console to know why it blocks the machine entering the wlan. May be a addressing issue or authentication issue. If you cannot reach it however it might have problems with the connection as well. Make sure that you allow connections to the wlan on Toshiba Vista laptop if you use a antivirus solution with a firewall or any other firewall.
If you can reach the machine (or even if you cannot reach) you must check whether you have access to the workgroup (you have to join if you are not in the workgroup which you use) and you must enable file and print sharing. If you run the windows firewall that would block you in as well. Its better if you can check whether the print spooling service runs. Start -> Run Type in services.msc Hit enter. Check and enable the service.
If you can reach the Dell using a ping: Check whether the dell machine can access the laptop. Use my network places. It will ask you for the credentials. Provide them. If any error occurred try detecting the network. Add the machine properly to the workgroup. Enable access to the machines via file and print sharing in windows firewall. (go to the firewall go to Exceptions tab and select the File and Print sharing)
Check this Microsoft resource as well.
Please rate the answer and a testimonial (comment) if the solution helped you to solve the problem...Thanks for contacting Fixya
May 30, 2010 | Linksys WRT160N Wireless Router
I cannot get my KM-C2525e Printer/Fax to print
the first thing I recommend is to get the IP address of your copier... goto the copier and press printer key, then on the display press printer menu and then print status page... On this page you are looking for the IP address...
Now goto your pc and press start... press run... type cmd and press cmd and hit enter... a little black box should pop up... type ipconfig... see if the subnet and the gateway match whats on your paper... if it does then continue... (if it does not then go back to the copier and go into the printer menu then pick interface and then network... then tcp/ip then change... then fix the subnet and gateway to match whats on your pc... then turn the copier off and then on)
your next step is to go into the black screen that popped up and type ping and the ip address and hit enter... so if your copier ip address is 192.168.1.5 then you type ping 192.168.1.5 and hit enter...
if you get timeouts... then verify that network cable is connected... and that you see green lights where the cable is connected... if you don't then disconnect the network cable and ping again... if you get a signal thats not timed out you have an ip conflict... if that happens change the last digit of the copiers ip and ping until you get one that has gives you a timeout then change the copier IP address...
next test is to go to the web browser of your pc or windows xp and right where you would type in google.com or yahoo.com type in the ip address for the copier... if you can pull up the copier's command center then the issue is drivers... if not then look at your network... if you normally have internet and you cann't get internet... your network is down... copier shouldn't work until network goes back up...
now if you get no timeouts when you ping and you can pull up the ip address in browser and get command center... your next step is to get the right driver... goto www.usa.kyoceramita.com then goto downloads then where it says choose a product select color copiers then where it says select model select your model then on the next screen pick find...
now for the right driver...install the uniprint driver 8.4... the first driver their... it will dither between a 64 bit and 32 bit pc... so you don't have to do anything but install it... when installing it... select network copier... then when it asks for port select tcp/ip and enter copier address and make sure when it shows you... the list of copiers to select kmc2525e... and follow the steps... it does have an option to detect the copier this doesn't always work but if it does... then the copier IP address will pop in the driver install and you select it and it does everything else...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 14, 2009 | Computers & Internet
I cant get my computer to find my scanner on my ricoh 2035
if you are adding it to your network... then you are doing ip printing... verify that nobody else on the network has the same ip address by unplugging the network cable from the copier and doing the following... goto start... accessories... command prompt... (black and white blox...) ping the copier... lets say ip is 192.168.168.168 then you ping it by typing ping 192.168.168.168 and hitting enter... if you get 4 time outs then ip is good... next step is to reinstall your print driver...
Dec 08, 2009 | Ricoh Office Equipment & Supplies
Print spooler unable to connect tp printer,cable
Print internal configuration page and check for IP address in printed sheet and try to compare with the driver information
Check for LED at network card if it’s on
Try to send ping command to IP address to verify connection and if reply is confirm
Uninstall driver and reload and try to search the printer with IP or hardware address while loading driver
If still any problem it could be network card have problem need to be replaced
Nov 07, 2009 | HP Color LaserJet 2600n Printer
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
So you verified ICMP traffic isn't blocked and it appears the servers allow the netBios traffic to pass.
On the client machine, check to make sure the windows print and file sharing is installed and the machine isn't blocking netBios traffic.
Make sure TCP ports 137,139, and 445 are open on the xp machine and any devices in between.
It's acting like the TCP data is being blocked by the client machine.
HTH,
-Aaron
Sep 28, 2009 | Microsoft Windows XP Professional
Good day, pls. help me, how can i install network ip address for konica 7035. thanks alot
Using arp command (Windows 95/98/NT/2000)
From Windows 95/98 MS-DOS prompt or at Windows NT/2000 command prompt, you can use the arp
command to assign the IP address to the network interface card. It is necessary that TCP/IP is set up
correctly on the computer that will execute the arp command. Perform the following procedure:
1. At Windows 95/98, select [MS-DOS prompt] from the [Start] menu. At Windows NT/2000, select
[Command prompt] from the [Start] menu.
2. Execute the arp command. For example, if the MAC address of the network interface card is
00:11:22:33:44:55 and the IP address to assign is 192.168.0.128, then input as shown below,
and then press [Enter].
(Example: C:\>arp -s 192.168.0.128 00-11-22-33-44-55
3. Execute the ping command for the assigned IP address. In this case no response is returned
from the network interface card.
(Example: C:\>ping 192.168.0.128
4. Turn off the main power supply to the print controller and the main body printer, then turn it
back on.
Chapter 2 Setting Up the Network Interface Card
2-4 Konica Network Interface Card INSTRUCTION MANUAL
A Status Page will be output. Check that the IP address is correctly set in the list. Or, when about 5
minutes have passed after having restarted the print controller and the main body printer using the
ping command, check that the network interface card responds correctly. The ping command is also
executed at Windows 95/98 MS-DOS prompt or Windows NT/2000 Command prompt. The example
of executing the ping command is shown below:
Aug 31, 2009 | Office Equipment & Supplies
Pls. help us,how can we used land cord to connect printer konica 7035 to computer. we already down load a driver from internet . we try many times to check sa IP address and test print but still we cannt...
Using arp command (UNIX)
From UNIX you can use the arp command to assign the IP address to the network interface card.
1. Turn off the print controller and the main body printer.
2. Log in as superuser on a host on the same subnet as the network interface card. However, if
the server resides on another subnet, complete this procedure to store the IP address in the
3. Find the MAC address of the network interface card. The address is printed on the Status Page
each time you turn on the print controller and the main body printer.
4. Edit the hosts file (usually /etc/hosts) or use NIS or DIS to add IP address and node name of
the network interface card. See the network administrator for the IP address. For example, a
network interface card with a name of printfast and an IP address of 192.9.200.200 has the
entry:
192.9.200.200 printfast
5. Add an entry to the arp cache for IP address and Mac address of the network interface card,
as:
arp -s 192.9.200.200 0:40:c8:0:0:ff
RS6000 (AIX) requires the ether option after arp -s. For example:
arp -s ether 192.9.200.200 0:40:c8:0:0:ff
6. Check the print controller and the main body printer to see that the network interface card is connected
to the network. Turn on the print controller and the main body printer.
7. Send a ping command to the network interface card to verify it is running on the network, as
for example:
ping 192.9.200.200 or ping printfast
The network interface card will not respond to this ping command but it will read its IP address
from the packets.
8. Turn off the print controller and the main body printer and back on again and then send the
ping command again to verify that the network interface card obtained its IP address. A confirmation
message displays as:
192.9.200.200 is alive
9. Remove the entry from the arp cache using the following command. Specify the network
interface card either by its IP address or by its name, for example:
arp -d printfast
Konica Network Interface Card INSTRUCTION MANUAL 2-5
Using MAP
By using MAP (Management Access Program) included the CD-ROM that comes with the network
interface card, you can automatically identify the network interface card on the network and set it up
for TCP/IP by using Web Utilities. To use this method to assign the IP address to the network interface
card, the following procedure should be performed on computers in advance:
• TCP/IP correctly configured
• IPX/SPX-compatible protocol installed
• MAP installed and MAP setup correctly executed
About how to set up TCP/IP and how to install IPX/SPX-compatible protocol, refer to Windows Help
menus for example. For MAP, refer to “Using MAP (Management Access Program)” in this chapter.
To change an IP address already assigned to a network interface card, you can not use the
arp command. Use Web Utilities instead. These methods also allow you to set up subnet
mask and default gateway, etc.
Using NIManage
Refer to “Chapter 7 AppleTalk Configuration”.
 Accessing Web Utilities
The network interface card is provided with an HTTP server having Web Utilities. By accessing this server,
you can change settings of the printing system. There are two ways to access Web Utilities, through a Web
Browser, either through Netscape Navigator, version 4.x or greater or through Internet Explorer, version 4.x
or greater.
• Use MAP to have the network interface card on the networks identified automatically, thereby accessing
Web Utilities.
• Use a Web Browser to type the IP address assigned to the network interface card, and thereby access
the Web Utilities. For example:
http://192.168.0.128/
If you designate the proxy setting in your Web Browser you cannot access the Web Utilities.
For more information see your network adminisrator.
2-6 Konica Network Interface Card INSTRUCTION MANUAL
A utility called MAP is provided on the CD-ROM that comes with the network interface card.
This program automatically identifies the network interface cards on the networks and lists them on Web
Browser screen. From this Web Browser list you can select a network interface card to change its settings
and control Web Utilities.
Aug 31, 2009 | Konica Minolta Office Equipment & Supplies
Cannot find print server at all
How this works: Restoring the PocketPrintServer to Factory Defaults In most cases, the best way to restore the PocketPrintServer to factory defaults is through "telnet". However, if you are unable to connect to the device because of a configuration error, use the following method which does not require a network connection. To restore the PocketPrintServer to factory defaults, complete the following steps: 1. Disconnect the PocketPrintServer from the network and power cycle it. When it powers up, the LED will rapidly blink orange for five seconds. 2. Power down the device during the rapid orange blink period. Power up the device and power it down during that orange blink period two more times. 3. Reconnect the network cable and power up the PocketPrintServer. It will have restored itself to factory defaults and will rapidly blink green as it searches for a RARP or BOOTP server to find an IP address. Gleaning If an IP address has not been permanently assigned when the PocketPrintServer is powered on or reset, it will look for a "ping" packet on the network. If the PocketPrintServer receives a "ping" packet within two minutes, it will accept the IP address in the "ping" packet as its own address. To use Gleaning, you must have super-user privileges on a UNIX system. Gleaning also works under Windows 95 and Windows NT. 1. Add an entry in the ARP table that assigns an IP address to the Ethernet address of the PocketPrintServer. To do this, use the "arp" command. arp -s temp Example: arp -s 192.168.42.24 00:02:16:00:00:01 temp 2. Start a continuous "ping" to the PocketPrintServer. ping Example: ping 192.168.42.24 On some systems, this may require an additional parameter. Some implementations of "ping" only send out one "ping" packet which could get lost in transit. Check your system documentation for more information. 3. Connect power to the PocketPrintServer. The PocketPrintServer will "glean" its IP address from the "ping" packet. This IP address will remain in effect until the PocketPrintServer is power cycled or reset. Therefore, a permanent IP address should be assigned by running the ExtendView TCP/IP utility or via "telnet".
Jan 30, 2007 | Extended Systems Pocket Print Server
69,805 people viewed this question
Clive
Clive
old marine
old marine
Ekse
