Question about Peg Perego John Deere Gator HPX Ride on Toy
Rear wheels- When the gas pedal is pushed on the John Deere Gator, should both wheel engage and spin? Only one rear wheel turns when gas pedal is pushed. No sure if this is a problem.
  • Anonymous Apr 18, 2009
    only one rear wheel turns when gas pedal in engaged. this problem recently started - both rear wheels should turn - does anyone know how to correct?
    Problem Solver:
  • 19 Answers
Both wheels should spin in 2nd gear. Only one wheel may spin in 1st, but if you put a little pressure on the one wheel that spins it should make the other wheel start spinning.
But both wheels should spin in high gear at the same time.
Hope this helps. If there is more help you can also ask these guys at this website. http://www.shopjandl.com/ I get my parts from them and they seem to also work on them as well
Posted on Apr 21, 2009
SOURCE:
John Deere JS-35 self-propel will not engage now. Help!
Check under the cover of the self propel unit to see if the belt is off the bearing or broken.
Feb 04, 2018 | Garden
Peg Perego John Deere Gator left wheel wont engage in 2nd gear, just replaced both motors and problem still exists. Any help?
disconnect the wires from one of the motors and check to see if it works in all gears, then do this with the other motor, then swap the wires from the left side to the right and vice versa, if both wheels spin in all the gears then you need a new shifter switch
May 22, 2012 | Peg Perego John Deere Gator HPX Ride on...
I have one of the first ones that came out that was never used bought it for my son and it get no traction at all.
are both of the rear wheels spinning when you push the foot pedal, lift the rear end when you verify this
Nov 28, 2011 | Peg Perego John Deere Gator HPX Ride on...
How do we replace the rear wheels on the John Deere Gator?
remove the center cap then bend the metal push nut with a needle nose pliers and pull it off then pull the wheels off leaving the axle in place
Jun 07, 2010 | Peg Perego John Deere Gator HPX
Can anything be done to add grip to the rear wheels of a perego gator
first of all make sure that both wheels are turning in all gears, you might have a bad motor
May 20, 2010 | Peg Perego John Deere Gator HPX
I am replacing the wheels on a john deere gator. Is there a trick to getting the wheels off and putting the new ones on. I thought I'd ask before I tried.
1. Remove the center caps from the rear wheels
2. use a 13mm wrench on each side and loosen the bolts
3. remove the rear wheels
Dec 02, 2009 | Peg Perego John Deere Gator HPX Ride on...
Open Questions:
See all Peg Perego John Deere Gator HPX Ride on Toy Questions
Peg Perego John Deere Gator HPX Ride on Toy Logo
1,665 people viewed this question
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
