There is some free (for home use) software called "Recuva" that you can use to do this. It will look for any files that can be recovered. Provided the card has not been used since the files were deleted the files should be recoverable.
You can find the software here:
http://www.piriform.com/recuva
Or you can search yourself for "recuva" in Google. It will be the first unsponsored link in the list of results.
You need to insert the card into the computer that has recuva on it and then select the correct drive letter in the software and then scan for deleted files.
Good luck.
Firstly,
stop using this memory stick immediately in case
that any new file would overwrite your original ones and make them gone
permanently. So, you should take care!
Secondly, plunge this memory stick to your computer and prepare to retrieve
all your deleted pictures.
Thirdly, apply a deleted photo
recovery freeware to retrieve all your deleted photos back successfully:
http://blog4mark.blogspot.com/2012/12/photo-recovery-after-delete.html
I believe this data recovery freeware can
work perfectly on your memory stick just in the same way as it completely retrieves
all the deleted data of my friend off from his phone memory card. Just give it
a shot!
Fourthly, save and back up all the restored photos on a different memory card
or drive in case of data recovery failure.
Note:
Never forget to back up everything important at
least on two memory cards or locations in the future.
You can download the deleted files from this link http://www.crazyspeedtech.com/recover-permanently-shift-deleted-files-windows-8-7
1 week ago, my friend deleted his 500 photos from memory stick but someone suggested him Remo recover tool and he get back all his photos without any extra effort. You can also give a try to this utility, it may aid you.
