Amana ARGS7650SS Gas Kitchen Range Logo
Posted on Apr 17, 2009
Amana Oven Door won't open. Latch to lock it is broken.
I turn on the self cleaning cycle on oven. I think my son broke the level that locks the oven and now it will not open. [email protected]
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1160
Points
After pressing Self Clean, Adjusting the Time and Pressing Start, the self cleaning cycle shows the # F57_ on the read-out. I tried to cancel and now the door opens, but I can't get the Bake to begin when I press Start. No matter what I press LOC flashes on and off, but the door is unlocked and the heat is off.
Please help!
Susan, PR
Gas range oven door with not open
Your self cleaning cycle is running. When self cleaning is running the door is automatically locked and will not unlock until the self cleaning cycle completes or self cleaning is turned off. You should be able to just turn off the self cleaning cycle and the door will unlock. Do not try to pry open the oven door. You will just damage the door and/or the catch.
6helpful
Oven sef clean latch locked but door is open and I cannot clos it. I inadvertantly urned it to self clean and openedthe door and the latch is locked in self clean position. How do I release the latch so I...
Ok. Open the door and find the oven light switch(es) (some models had two switches). Press the switch(es) in and see if the latch goes back to the home position. If not enlist a volunteer to turn on the self clean cycle while you are holding the switch(es) in. Just after the self clean starts have them hit cancel and wait until the lock comes back to it's "home" or unlocked position.
Good luck!!
1helpful
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
1helpful
Can I clean a TruTemp oven with soap and water without ruining it?
Yes you could clean it.
Check few details :-
t the bottom of this post you will find the web address for your ranges manual and the self clean system is in side this manual.
How to self clean
If your model has a door latch, never force the latch handle. Forcing the handle will damage the door lock mechanism.
Before a Clean Cycle
For the first self-clean cycle, we recommend
venting your kitchen with an open window
or using a ventilation fan or hood.
Remove any broiler pan, broiler grid, all
cookware, probe and any aluminum foil
from the oven—they cannot withstand the
high cleaning temperatures.
NOTE:
If your oven is equipped with nickel oven
shelves, remove them before you begin
the self-clean cycle.
If your oven is equipped with gray
porcelain-coated oven shelves, they may
be left in the oven during the self-clean
cycle.
Soil on the front frame of the range and
outside the gasket on the door will need to
be cleaned by hand. Clean these areas with
hot water, soap-filled scouring pads or
cleansers such as Soft Scrub®. Rinse well
with clean water and dry.
Do not clean the gasket. The fiberglass
material of the oven door gasket cannot
withstand abrasion. It is essential for the
gasket to remain intact. If you notice it
becoming worn or frayed, replace it.
Wipe up any heavy spillovers on the oven
bottom.
Make sure the oven light bulb cover is in
place and the oven light is off.
IMPORTANT: The health of some birds
is extremely sensitive to the fumes given
off during the self-cleaning cycle of any
range. Move birds to another well ventilated
room.
NOTE: Use caution when opening the upper
oven after the self-clean cycle has ended.
The oven may still be hot.
How to Set the Upper Oven for Cleaning
On models with Gas/Control Lockout,
touch and hold the Gas/Control Lockout
pad for 3 seconds to turn it off.
NOTE: The surface burners must be turned
off prior to the self-clean start time.
Touch the Self Clean pad.
Using the number pads, enter the
desired clean time, if a time other than
4 hours is needed.
Clean cycle time is normally 4 hours. You can
change the clean time to any time between
3 hours and 5 hours, depending on how dirty
your oven is.
Touch the Start pad.
the clean time remaining. It will not be
light goes off.
To stop a clean cycle, touch the Clear/Off
off, indicating the oven has cooled below
of day.
the door.
desired clean time.
Touch the Delay Start pad. The earliest
display.
Using the number pads, enter the time
to start.
light goes off.
a latch.
pad
After a Clean Cycle
oven cools.
soap-filled scouring pad and rinse thoroughly
repeat the cycle.
unlock.
touch the Clock pad to display the time
of day. To return to the clean countdown,
touch the Cooking Time pad.
If the shelves become hard to slide, apply a
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
6helpful
Whirlpool self cleaning oven Accubake. 2 yr old
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
4helpful
Cleaning over but lock light will not goff and i can not open my oven
3helpful
Door locked after shutting down cleaning cycle earlier than
2helpful
LED says "Locked" can't turn on stove. How do you unlock it?
14helpful
Self-cleaning oven door won't open
May 15, 2009 • Ovens
2helpful
2answers
Self cleaning oven door locked before I got the door closed.
Try holding in on the door switch while resetting the clean cycle.
This should rotate the latch. Once the cycle starts, cancel it. The latch should go to the unlock position.
You will have to hold in on the door switch during all these steps.
If this does not work, post back with the complete model number from the oven and I will see what else I can come up with.
Top Amana Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
