Konica Minolta Bizhub 7145 Copier Logo
A
Anonymous Posted on Sep 18, 2013
Konica Minolta Bizhub 7145 code error f-77-27
3 Related Answers
Anonymous
  • Posted on Nov 19, 2007
SOURCE: konica minolta bizhub 350
• The Fusing Roller Sub Thermistor does not
detect the required temperature within 30 sec.
after a warm-up cycle has begun; therefore, the
copier does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
Check that the H1[ fuser lamp] comes on when the Main Power
Switch is set to ON, and correct or replace as necessary.
Check that the H2 comes on when the Main Power
Check the installation of the TH1 and the TH2, and
correct or clean as necessary.
Check the operation of the TH1.
Remove CN80 (4P), and then check that the resistance
across CN80-2 and -3 on the Thermistor is
infinity.
5
Check the operation of the TH2.
Remove CN81 (4P), and then check that the resistance
across CN81-2 and -3 on the Thermistor is
infinity.
6
Check the continuity of the H1.
Correct or replace as necessary.
7
Check the continuity of the H2.
8 Change PU1 - -
9 Change PWB-A
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 19, 2010
SOURCE: desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
hamzaskilltd
amir hamza
  • 318 Answers
  • Posted on Aug 07, 2010
SOURCE: Solution for error code c2557 konica minolta bizhub 250 machine
ADTC sensor failure
Konica 7145 say PM fixing unit (Web) won't copy but will print
have tech come out and replace the web roller above the fuser unit, and clear the counter after install. THAT IS LEGACY MACHINE google for the web roller
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
2helpful
Where is the hard drive
check the following link, maybe it will help you:
http://diagramasde.com/diagramas/otros/7145-7222-7228-7235SM.pdf
Usually, the hard disks are located where all the boards are, due to the fact that hdd needs to be connected with this boards and if the wires are longer, interferences might appear.
If you need anything else, just drop us an email at [email protected]
Also, please visit our websites, we're sure you'll find useful things there
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Where is the hard drive on konica minolta 7145 biz hub
In the rear of the machine
Konica 7145
fuser code hot part replace it
2helpful
My konica minolta bizhub 7145 b/w copier is showing error code F-51-5 The copier will power up and then seize. The copier is about 5 years old with a total count of 320,000 copies
Hi the problem is going to be with the M1 motor most of the time replacing this motor will fix the issue However in rare cases if it still gives you the same error after replacing m1 motor then you will need to change CB Main Body control board my advice is to replace the motor and if it still gives error code replace the cb board but it will fix your problem
1helpful
What are codes F-34 and F-35?
These are heat sensor abnormality error codes in Konica Minolta 7222/7145/7135/7235/7228 models.You did not mention the model.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
