Delonghi Lattissima EN 660CW milk frother not frothing
I don't know why my answer posted in the comments section, so here it is in the proper area.
I had the same problem and was ready to send it in for repairs, but I
talked to a great guy at Nespresso who helped me fix it myself. The
problem was when I pushed the latte button, it would only froth milk for
a second or two and then the espresso would start pouring. It basically
refused to make a latte. Here's the things he had me do:
1)
Descale immediately. I have an older machine, and descaling once a year
does NOT cut it. He told me descaling every 5 months at the bare
minimum, if your machine is not having any problems at all. Descaling is
usually the main problem for lack of froth. I descaled and it seemed
like the machine was working better almost immediately. I also ran 4 - 5
tanks of water through the hot water spout and the main espresso part
(but mostly this is because it seems to take this much flushing to get
the smell of the descaling solution out).
2) Reset your machine
to factory settings. I have a classic Lattissima, so this is how you do
it on that machine. Turn the machine on and wait until the drink buttons
are steady (espresso and hot water buttons are no longer blinking to
warm up). Then press and HOLD the power button until the espresso and
hot water buttons BLINK THREE TIMES. Then they'll go back to steady
again. You're now back to factory settings.
I did notice that I
started having the trouble after moving the machine, so I'm not sure
which of the above solved the problem. The main thing is it worked and
I'm back to yummy lattes!
