Click on Start Click on run Make sure the run line is clear Type services.msc You will see a list of services Make sure all items below are set to automactic To make the changes double click on each item line change to automactic if diabled. Then click apply when you are done. Printer Spooler LexBce Server Remote Procedure CallRPC) Restart the computer Hope This helps
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the
print spooler service)
2. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the
Try to print a document again to verify that the problem is fixed.
