My q turned off when i had full battery and wont turn on unless it is plugged into the charger. when i get it turned on the screen is back and the message motorola flash mode bootloader version: boot_c_03.05.00r_mpap usb cable connected comes up what can i do
Have you tried a Master Re-set when the phone is off? Hold the center key and the power button for at least a FULL minute to a minute and a half. You will see the provider's splash screen, but hang tough.
This works best with the device on a flat surface rather than holding it.
I want to put my Q in bootloader mode to see if I can get the Motorola update to run. Does anyone know the key combo to make it do this? I thought it was "A" + "Shift" + "Power".
my motorola is in flash mode. bootloader version: boot_c_03.08.00r_mpap charger connected please connect the usb cable. what do that mean and how do i get out of it
Y q turned off when i had full battery and wont turn on unless it is plugged into the charger. when i get it turned on the screen is back and the message motorola flash mode bootloader version: boot_c_03.05.00r_mpap usb cable connected comes up what can i do
My phone is written Motorola flash mode i dont know what to do
Sir i have problem of motorola flash mode in my moto q mobile
I downloaded the motorola software updater and connect the phone via usb cable to the computer and updated the software. Once it was finished it restarted the phone and all was good. You lose all your information on the phone but at least you can save the phone with no cost. This solution may not work for everyone and I am sorry if it does not work for you. It however did work for me. Good luck.
Hay... this will help u
Download motorola tool flash and install the software
connect ur phone to pc
this software(motorola tool flash) automatically detect ur phone firmware(eg:R47A_G......) download firmware same from net.next
open write menu add backup file(u downloaded firmware) and then clik write...
automatically run this program
further details:[email protected]
Is there any way to make my moto q work on reliance? I will be very very thankful to you. [email protected]
I have a moto q that is in flash mode please help me fix this!!
I just unbricked a Moto Q with these instructions. Be sure that every time the USB is found and Active Sync is started on the Desktop, dispatch the "Cannot find email client..." message and minimize Active Sync. It takes 3 boot cycles to reload the software and the longest delay imaginable but it did work.
You can get it out of flash mode. READ MY POST.
To sum it up, I've found that the usb cable that comes with the Motorola Q is complete $hit. I've ordered 8 Moto Q's and had this problem with two of them. Each usb cable that came with each Q was crap. Windows didn't recognize the Q correctly with it - ESPECIALLY in bootflash mode.
I don't know why but the usb cable that came with my old Nextel BlackBerry 7510 worked every time like a charm, when the one with the Q wouldn't work.
To get the Moto Q out of flash mode here's EXACTLY what I did.
1. Download and install the Motorola update software for the Motorola Q (available through the Motorola website).
2. Get yourself a blackberry 7510 usb cable from a sprint/nextel store (take the thing back after you're done with it if you aren't entirely convinced that it's superior to the crap cables Motorola is shipping with the Q's - Sprint should let you return hardware (cables) for a full refund; just tell them you bought the wrong one and it doesn't fit your phone (make a phone model up that doesn't take a usb cable).
3. Turn OFF your phone.
4. Launch the Motorola update software (after it's been installed of course).
5. Connect your phone (while it is off) to your computer via the blackberry 7510 usb cable.
6. Click NEXT on the update software until it gets to the point where it is trying to search for your phone (connected device). Immediately turn the phone on once this process has begun.
Your phone may go into the dreaded "Flash mode" screen, but now that it is connected to your computer and the Motorola update software is running it will recognize the connected device (yes, even though windows mobile 5 isn't running) and will re-flash the device.
If at all it says that it cannot find any connected devices, go back to the start of the update software process and leave the phone on from the start as you make it search for connected devices again.
I brought 2 Motorola Q's out of a constant "flash mode" screen this way.
Again, I have absolutely no idea why my blackberry 7510 usb cable works when the Motorola Q usb cable doesn't... they are BOTH usb cables and physically look identical - BUT THE MOTOROLA USB CABLES DO NOT WORK FOR ME, ON ANY OF THE 5 COMPUTERS I'VE ATTACHED THEM TO & ATTEMPTED TO USE THE MOTO Q UPDATE SOFTWARE ON.
If you happen to live in the San Francisco bay area, I'd be happy to meet up with you at a local starbucks or something to guide you through it if you'd like (I'll even bring my blackberry usb cable). These Moto Q's are a pain in the a$$ and if I can help someone avoid the BS I've had to put up with, I'm glad to do it.
hi i got 4 motorola q in flash mode i need some help email me at [email protected]
thank you
i have a moto q and its a 1g and i need to get it up graded to 3g is that something i can do.
My Q is stuck on flash mode. i need some help really fast. my Q wont even cut on. i have read all the postes up here and nothing has seemed to help me i have also downloaded the motorola update but it wont work b/c it says my fone isnt connected WHEN IT IS!!!! this is all coffusing so if some one call email me at [email protected] and tell me please!!! I CAINT LIVE WITH OUT MY PHONE!!!
None of this works my phone won't turn on so how can i update it...Thanks
To the Guest that posted solution #2 using the blackberry usb, or anyone else who thinks they can help. I have the same problem, with the Q being stuck in the bootloader flash screen, and I've also figured out how to reinstall the windows os using RSD Lite, but my phone won't stay powered on long enough for it to complete the process. It seemed like a couple days ago I was able to plug the phone in to charge and it would work, but now I'll leave it on for hours and it will turn off after just a minute or less of trying to do the reboot process. How could I charge it with it stuck in this mode? ALSO I've tried doing the motorola update software with my Q already and the usb cord I was using allowed my Q to be discovered by the computer, but said that there were no new updates available for the phone, so is it worth my time to go buy the blackberry usb, or will it not help me? Thanks
I have the same exact problem. My phone will not turn on unless I have it connected to the charger and when it is on it just gives me the same error.
my q turned off when i had full battery and wont turn on unless it is plugged into the charger. when i get it turned on the screen is back and the message motorola flash mode bootloader version: boot_c_03.05.00r_mpap
when i hold the power button to turn my moto q on, it shows the verizon wireless screen and then goes blank and wont turn on unless it is plugged into the charger
same problem....when turned on screen is black and says usb cable connected or connect usb cable and when i do nothing....please help
i was charging my phone and it just turned off when it hit full and wont even turn on unless it is plugged in. when i plug it in i get the black screen and it says flash mode bootloader
The same I am getting Motorola Flash mode Bootloader version message and not even sure if the phone is even charged and how do you turn it on and then it just shuts off.
says hook up usb cable its in flash mode wont' start up
Got the phone less than 24 hrs. Message showed up. Have been on the phone for over an hour, still no solution.
Ive had the phone for about 3 weeks now and i have the same problem. verizon tech support had offered no help? whats the deal?
my moto Q is in flash mode bootloader version says charger is connected but it tells me to connect to usb BOOT_C_03.08.00R_MPAP my phone been this way for 24 hrs dont even know if its charging can some one help me.
usb cable connected comes up what do i do too fix this problem?
it wont do any thing
motorola flash mode bootloader version: boot_c_03.08.00R_MPAP
the dau before i got the bootload curse i noticed that the phone would not charge with my car charger and would only recharge in the cradle
Phone is 3 weeks old. lucky me
Used my phone tonight with bluetooth and it locked up. Couldn't get it powered down and removed battery. Phone would not upload windows and I now have the black screen if plugged into a charger or computer. I am leaving on vacation tomorrow and have all contacts I'm going to visit on that phone! How can I fix it?
MOTOROLA Q SMARTPHONE GOES TO A BLACK SCREEN IN FLASHMODE, BOOTLOADERVERSION: BOOT_C_03.95.00R-MPAP. PHONE WILL NOT TURN ON AND HAS FULL BATTERY POWER.
usb cable connected
same problem
Motorola Flash Mode
Bootloader Verion:
BOOT_C_03.05.00R_MPAP
USB Cable Connected
I plug in the USB port and it says :motorola flash mode.Boot loader version: boot_c_03.08.00r_mpap. what do i do to fix it?
I'm having the same problem. I've tried several different USB Cables as suggested, but nothing. I can't even turn my phone on - when i try to do the software update, it 'disconnects' after 15 seconds or so.
help!
i just got this phone. its used and i dont know who the carrier is or was. i cant turn it on, and when i plug it in to a wall charger it comes up as fash mode-bootloader version- and at the bottom says to plug in the usb cable. When I plug in the usb cable to the computer, the updater that i installed wont ever reconize the phone is connected to the computer. i tired the master reset and got nothing. Can Anyone Help me out???
well i just want to know the code to put a verizon wireless motoq in flash mode and install the sprint firmware
i just bought a new phone. the Q is junk.
my phone is messed up. when i plug it in it doesnt do anything.but when i unplug it the flash mode bootloader thing pops up and dissapears after 15sec.any help would be nice.
My phone displays Flash mode and will not turn off or on with or without the battery!
i turned my phone off and then it started up an hour later and said flash mode boot all that stuped stuff
i have the same problem what do i do????????
usb cable connected comes up what can i do. and i tryied to do your recommended step to fix but the device backlight scren with flash mode message stay on for 15second loading has started then device screen goes black and software installer stop and said reconnect the device. can you help me
I have same problem and no way to solve it Help
does any1 kno how 2 escape the flash mode?
nothing i tried on here works....can anyone walk me through the steps please?
its in the flash mode and won't let me do nothing ):
can't turn it on or nothing.. and it sucks.
help.. it's in flash mode.
stupid phone...mine is doing the same thing!
I just took my phone to the Sprit service center, and they said it is not fixable.
i have the same problem as 1blackdude except my Bootloader Version is: BOOT_C_03.88.00R_MPAP
I have the same problem with my phone nothing is working! :-(
Motorola Flash Mode
Bootloader Verion:
USB Cable Connected
what is that anyway?
