How do i change the needle? [Simplicity Serge Pro SW432]
You need a set of allen wrenches... a very small one works
1. Turn electrical power off. 2. Turn hand wheel towards you until the needle comes
to its highest point. 3. Use the allen wrench to loosen the left or right
needle clamp screw, and remove the needle. 4. Place the side of needle toward back of the machine
and insert in needle clamp as far as it will go. 5. Retighten the screw.
SOURCE: Need a set screw for
you could try a generic one from this website and see if it fits?
http://sewing-machine-parts-store.com/list.asp?subcat=Screws
Buy a new needle.. hehehee...
In Simplicity Serge Pro SW432, you need Hex L-wrench. In some machines u need just a screw driver
cannot get needle removed. have loosened screw needle will not move
Couple drops of WD-40 might help to remove your needle.
