SOURCE: KM-2530 with C0050 error code ?
it's the the expansion card on the main board in the middle, has a yellow circular cmos battery. Either its faulty or popped out during moving the machine. if faulty, replace.
SOURCE: Copier giving error
Just open and close door on the left side of Machine.I had that problem.
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
SOURCE: My Kyocera Mita KM-C380 copier check waster toner tank
Hello sir; the waste toner tank haveto be clean up thoroughly, aspecial the bottle neck .
