SOURCE: frigidaire air conditioner
remove cover .It might have two screws on the side or just pops off. Pull unit out from cover. if it does't move remove screws in back of unit near condensor
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
SOURCE: Frigidaire Air Conditioner - FAC102P1A Compact II th
I spoke with the Frigaire support line 706 374-4432. They said that the large piece of styrofoam, that extends from side to side and nearly top to bottom, is part of the unit. It should not be removed.
SOURCE: My portable frigidaire air conditioner bucket light on
The actual bucket is located inside the machine at the bottom. To access it, you must unscrew all of the screws and take the front panel off. You cannot empty it from this side so it is not worth taking the machine apart.
However, in order to empty the bucket, there is a small black plug at the bottom left hand side at the rear of the machine. Be careful when pulling out the plug because the water will immediately drain.
Good luck.
m
Hello Jim Hyde - Try pressing the reset button on the plug, if you haven't so already. If the unit continues to not heat up, contact a professional that works with your manufacturer to move forward accurately. Keep in mind that for some air conditioners the heating option is simply a supplement to help heat up a room but in most cases it will not completely heat up the entire room.
