:) Luckily, these GE touch screen models can now be affordably repaired.
Full official details on the fix are at http://www.microwavecontrol.com/jvm2070.htm.
Let me know if you have other questions.
William Edward Miller
[email protected]
August 2016
NOTE: This information applies to ALL of the General Electric touch-screen models below:
CVM2072 SERIES
CVM2072SM1SS
CVM2072SM2SS
CVM2072SM3SS
CVM2072SM4SS
JVM2070 SERIES
JVM2070BH
JVM2070CH
JVM2070SH
JVM2070SK
JVM2070WH
JVM2070BH001
JVM2070BH002
JVM2070BH01
JVM2070BH02
JVM2070CH001
JVM2070CH002
JVM2070CH01
JVM2070CH02
JVM2070SH001
JVM2070SH002
JVM2070SH01
JVM2070SH02
JVM2070SK001
JVM2070SK002
JVM2070SK01
JVM2070SK02
JVM2070WH001
JVM2070WH002
JVM2070WH01
JVM2070WH02
JVM2071BH01
JVM2071BH001
JVM2071CH01
JVM2071CH001
JVM2071SH01
JVM2071SH001
JVM2071WH01
JVM2071WH001
PVM2070 SERIES
PVM2070DMBB
PVM2070DMCC
PVM2070DMWW
PVM2070DM1BB
PVM2070DM1CC
PVM2070DM1WW
PVM2070DM2BB
PVM2070DM2CC
PVM2070DM2WW
PVM2070DM3BB
PVM2070DM3CC
PVM2070DM3WW
PVM2070DM4BB
PVM2070DM4CC
PVM2070DM4WW
PVM2070SM1SS
PVM2070SM2SS
PVM2070SM3SS
PVM2070SM4SS
These models utilize one or more of the following part numbers:
WB07X10731
WB07X10732
WB07X10733
WB07X10972
WB07X10973
WB07X10974
WB07X11113
WB07X11131
WB07X11139
WB07X11143
WB07X11192
WB07X11194
WB07X11195
WB07X11196
WB07X11302
WB07X11303
WB07X11304
WB07X11305
WB07X11306
SOURCE: replacing door handle on microwave ge profile
You will need to access the door handle mounting screws and remove them to replace the door handle. To access these screws on MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. This can be easily be accomplished by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel and pry the plastic up. Work your way slowly around the perimiter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful microwaves.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at pcappliancerepair.com for reference. Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
SOURCE: I have a GE Profile Spacemaker Microwave Touch Pad does not work
Sadly, GE does not make individual parts available for these controllers, so they cannot be repaired.
You have to replace the control panel sub-assembly (part number WB07X10733 in your case) and the best price I've found on that is $370.32 here (compared to $483.25 direct from GE).
In my opinion, this does not do much to inspire brand loyalty...
Or you may be able to find a whole oven on eBay for about that or less.
Sorry to bear bad news. Good luck.
We're happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer
Yes! but the whole keypad control or smart board will need to be replaced. I highly recommend a professional for this job and do a spot check on the rest of the unit.
SOURCE: Key pad on my GE Profile Spacemaker 2.0, Model JVM2070choo1 does not respond.
1) the control board is faulty. however you can try to clean the keypads for dirty , oxide, or corrosion, Of course you must try to unplugged the power cord and discharge the capacitor see the diagrams.
God bless you
