Water want come out
Clean sand granules out of the motor! the problem appears to be sand granules from the sand filter jamming the "pulse motor", unplug take the water cart off, unscrew the back cover, the one with the label (6 crosspoint screws) beware the 2 long ones holding the end! inside the cover there is a small bulge, next the pipe,, unscrew 3 screws these it reveals the motor squeeze the pipe clip slide back pull forward, to release motor blow through,the tiny hole backwards, until clear, you may have to use a blunt toothpick! to release, the stuck granules...Blow, blow, then reassemble
