Heating & Cooling Logo
A
Anonymous Posted on Dec 25, 2017
I purchased a Patton recirculating utility heaterPUH4842M-RHM from Home Depot on Sept. 15,2013. tried it, liked it, but I want more information, i.e., customer ratings, potential problems. I tried looking on line and couldn't find anything for this model. Can you help me with this? [email protected]
Shabna
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Dec 25, 2017
Shabna
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
275
Points
6
It's rating upto 4 out of 5 stars
Can I buy a heating element for this heater?
On google
Patton replace heating element Heaters Questions ... - Fixya
www.fixya.com > Forum > Tags > replace heating element > Heaters
Patton heaters replace heating element related questions and answers. Ask yourPatton ... I can't seem to find a phone number for the manufacturer to call for parts. Any help? ... Question about PQH307UM Electric Utility Heater. 1 Answer ...
Patton PQH307UM Electric Utility Heater Quartz elements ...
www.fixya.com > ... > Patton > Patton PQH307UM Electric Utility Heater
Patton PQH307UM Electric Utility Heater, quartz elements replacement related ...Element. Where can I find replacement quartz tube heating. Element Infrared ...
Patton PQH307UM Electric Utility Heater Element ... - Fixya
Patton PQH307UM Electric Utility Heater, element related issues. Get free help, solutions & advice from top Patton experts. ... The heating element is above the thermostat, and all you will see is a round disc with two wires attaching to. Ad.
Patton PUH680-U Utility Heater Replacement fan motor ...
Pump is plugged into a hot line and will not run. It ran just over 3 months and quit totally.
Hello Mr Johnson.
I will help.
I am timer expert at fixya. Fixya answers question. We are not home depot or warranty carrier for grunfos.
Here are some ideas:
1) Buy another pump at home depot and return defect in new package
2) Talk to manager at Home Depot.
3) Check if outlet has power. Plug recirc pump into different outlet.
4) Check if override lever is set to OFF, because pump will not run when lever is in OFF position: Here is photo I took showing positions for lever:
http://waterheatertimer.org/Water-heater-recirculation-system.html#lever
5) These devices are prone to surge event. Nearby lightning strike can burn out any electrical device by energizing wires. The surge can follow any path seemingly random trying to find path down to ground.
Add a comment and say what happens.
Gene Haynes
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
NEED REPLACEMENT MOTOR FOR PATTON 1010MP-HY FAN. WHERE CAN I PURCHASE THE MOTOR?
CTG ' Order 1010MP from PATTON ELECTRIC CO INC Now from CTG !
It looks like you can purchase a motor here.
Make sure you have the correct data from your motor.
There is also a contact button so you can probably call, too.
Good Luck,
Your FixYa Texpert,
Gary
Has the patton 682 been recalled? I am trying to decide between the 680 and 682 as I'd like to purchase one or the other. However, i just noticed on the internet that 682 may have been recalled. Is that...
Depending on the age of your heater, there were actually two recalls. One in 1985 and the most recent in December of last year.
This a link to the 1985 recall http://www.cpsc.gov/cpscpub/prerel/prhtml84/84025.html
This is the link to the most recent http://thestir.cafemom.com/home_garden/113974/huge_walmart_heater_recall_over This one list a number you can call for further information.
Hope this helps.
Looking for rubber feet for the patton floor fan.
If you can not find the exact parts, you can pick up a generic rubber foot from the Home Depot or even at Radio Shack. They will most likely have a self adhesive on them, but you may want to also add some electrical tape to keep them in place.
The toilet comes with a hard body flapper which utilizes a pretty straight-forward gasket. The gasket material failed within 3 months. The Korky that I purchased will not function properly. Impossible to...
We have just recently purchased one of the American standard cadet at home depot from a discount flyer and had it for about a day and took it back.
We Did not notice Any thing like a strong flush.
RECOMENDATION:
Take it back.
Home Depot sells a Kohler Toilet 1.6 Gallon Flush Install
This is all it said it was. It saves water for sure and has a quick flush.
We liked it so much we purchased two of them because everyone in the house only wanted to using our bathroom.
Hope this tip helps
David
15helpful
3answers
I purchased a Patton model PUH682 in October
Does anyone have any info on whether the PUH682 was actually recalled?
Top Patton Electric Heating & Cooling Experts
Paul Carew
john h
Are you a Patton Electric Heating and Cooling Expert? Answer questions, earn points and help others
