Hi, my girlfriend misplaced the power cord for her printer, and I can't seem to find one on ebay, or dell's website, and the one link I found in a discussion group:
http://www.http.com//accessories.euro.dell.com/sna/productdetail.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&sku=450-11224
Does not work...any solutions?
Look on the back of the printer and enter the service tag number here;\http://www.dell.com/en-us/shop/partsforyourdell/index?~ck=mn
It usually gets the original part number for you. Or call Dell directly: 1-877-717-3355
SOURCE: Dell Photo 926 Printer HELP!
Hello Jadamsfort.. try this link ..
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PRN_ALL_A926&os=WLH&osl=en&catid=&impid=
You'll need to input your system details but you should be able to get the drivers you need...
Hope this helps..
SOURCE: Dell Photo 926 - unable to scan
1. try to make a copy.
if it copy fine, then its an issue with software.
2. Try to scan with MS Paint,
Click on Start > All Programs > Accessories > Paint
Click on file > from scanners and camera > scan
It should scan if its not the windows issue...
3. Try different computer if it does not scan with Paint\
4. If it works with Paint, try to open Dell AIO center and try to fax from that too...
5. Turn the printer off, take the power brick out from back of the printer where power cable goes in , wait for 15 seconds to connect it back and turn on and try again to print, it should work fine
SOURCE: Dell Photo 926 Power cable
You can get it from site below:
http://accessories.euro.dell.com/sna/productdetail.aspx?c=uk&cs=ukdhs1&l=en&s=dhs&sku=450-11224
SOURCE: My dell 926 photo printer
change the power cord and if that doesnt help try a different wall outlet ... if that doesnt than hardware issue contact dell 18006249896
SOURCE: Dell Photo 926 printer scanning problems
Go to Control Panel, then Programs and Features. Uninstall the Dell printer software.
Then, go to Control Panel, then Device Manager. Locate the printer, right click on it, and select uninstall.
Disconnect the printer from your PC.
Go to the Support section of Dell's web site, download the latest driver for your printer.
Restart your PC.
Install the software. Connect your printer when instructed to, or after the software install has completed.
Let me know if you still have issues :)
The Dell 926 printer is an All-In-One model that you can use as a printer, scanner and a fax machine. When the printer becomes unresponsive there may be a communication problem between the printer and your computer. To correct this type of problem you need to first verify that the USB connector cable is not malfunctioning. You can do this by resetting the communication settings between the computer and the printer.
y1 Press the "Power" button to turn off the printer. Unplug the power cord from the electrical outlet or the power strip.
Disconnect the USB connector cable for the printer from the computer.
Turn off your computer from the Windows "Start" menu or by pressing the "Power" button.
Plug the USB connector cable back into a USB port on the computer.
Plug the power cord for the printer back into power strip or electrical outlet.
Press the "Power" button to turn on the printer. Press the "Power" button to turn on your computer.
Lost power cord
lost the cord in a move how do I find a replacement?
