Sceptre X32BV-Naga 32 in. LCD TV Logo
Posted on Apr 17, 2009
I have a 32 inch sceptre naga. when i turn on a tv, the blue screen appears for less than a second and then goes blank. the sound is still on. what could be the problem
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1362
Points
Mine does the same thing, before... it would come on when i turned it on & off. But now it blue screens then blank black. Blue means if it stays blue & i turn on my computer it will show all the computer stuff, i have not used TV yet.. But if you can get it to stay blue you can change things with the cc control, or swap..
If you find how to keep it blue let me know please..
  • Anonymous Apr 18, 2009
    but i use mine as a monitor for my computer, the blue screen now come on briefly then black screen, no sound, it also now have two lines that come from top to bottom about 18inches from center-line both ways. I use to turn it on & off to get the blue screen to stay on but now it won't budge. Turns black instantly.. I had it up for a while that is when i saw to two lines..
1helpful
I have a sceptre 32 inch tv and there is only sound no picture
usually problems with the screen such as sound but no screen means the backlight or power inverter is gone. you can check this out by turning the TV on or off. If you faintly see the screen pop up then go away, and if you shine a flash light on the screen you can still barely see it then it's that problem. You have to buy parts from your manufacturer or open up the TV and see if any transformer or capacitors are toast.
I have a sceptre x20g naga III screen goes blank
if you have the warranty, return it and get a new one free. ok
3helpful
I HAVE A SCEPTER 32GV-KOMODO. WHEN I TURN IT ON THE SCREEN COMES UP AND SAYS SCEPTRE IN RED AND THEN GOES BLANK. NO MENU OR ANYTHING COMES UP
a chip on the main PCB went out. I just replace the board on my X32GV, You can sometimes find one on ebay, you can also get free live tech support from sceptre here. Or send it in for repair if still under warranty here.
hope this helps
Sceptre naga blue screen when tv on then turns blank, sound on
i have a secptre t v turns on for a sec and screen is blue then goes to blank screen can anyone help
X20G-Naga III screen goes blank after 1-2 secs
most common lcd monitor break down, check all electrolytic capacitors for leakage and loose board solder specially on the ccfl inverter section.
Top Sceptre Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sceptre Televison and Video Expert? Answer questions, earn points and help others
