Hi, I have thoroughly cleaned my M300 and whenever I try to use it it just says 'Fill Water'. The water tank is full and I have tried emptying it and filling it up with different amounts and jiggling it around to make sure it is in the right place. However, the machine just continues to say 'Fill Water'. Any ideas? Thanks.
It just means that the pump needs primed. Turn on at the wall and on the machine, wait until screen says ready (make sure water tank full), then turn steam handle on RHS to on (do not push the steam button). the pump will prime until water comes out of the steam nozzle. now turn off the steam handle and you are ready to go!
Unfortunately only a bit of water comes out before "close tap" comes up. Water continues to pump int overflow and fills base.
Any ideas?
I'm having the same problem with my brand new gaggia syncrony. i've tried the same things, including filling it with a pitcher while it's still on the machine. any ideas?
I have the same problem with the M300,
i want use it since 1 year of inactivity and i have now this trouble
I turn on( i don't understand "at the wall"- i'm french) the machine,
but the screen never says "ready". It says allways "Fill water"
(remplir eau). i Can turn steam handle to on, i heard the noise of the
pump, and after some seconds => Fill water
Thx
