Hello here is the mainboards homepage:
http://www.msi.com/product/mb/RC410M-F--L--FI--LA.html#/?div=Detail
Any ATX power supply will fit your mainboard.
I will recommend to buy a power supply of a good brand like corsair, because the cheap one does not last long.
I would choose one not under 500 watts.
If you change the powersupply yourself, please take antistatic precautions when working on the mainboard.
Pricerange is 100 to 200 dollars depending on how big it has to be.
Remember also to arrange cables so its not blocking vents and fans.
Good luck
SOURCE: PC Power up Problem
hi im josh in cebu phils. friend i suggest to check the two cables from power supply the 16pins and the 4pins 12volts.be sure you mounted it firmly to avoid this connection and to provde you with enough power to make the mainboard work. good luck.
