eMachines T5274 Desktop PC Logo
Sharon Posted on Sep 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My E Machines Desk top model #EL1200 boot up how do I get it to last known good configuration?
Alex Kagunda
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 199 Answers
  • Posted on Sep 17, 2013
Alex Kagunda
Expert
Level 2:
New Friend:
Cheetah:
Answers
199
Questions
Helped
42229
Points
440
When you power the machine press f8 from their select from the boot menu
Windows will not load can not get to desk top .notebook start files and or boot log is corrupt.system will not boot .windows 7 was just installed.
AS YOU ON THE SYSTEM AND EVEN BEFORE WINDOWS STARTS KEEP PRESSING THE F8 KEY CONTINUEOUSLY. A MENU WILL APPEAR. SELECT SAFE MODE AND ENTER. WINDOWS WILL LOAD IN SAFE MODE. THIS WILL SOLVE SOME OF YOUR PROBLEMS. NOW RESTART THE SYSTEM IN NORMAL MODE.
IF THIS DOES NOT WORK SELECT "LOAD WINDOWS WITH LAST KNOWN GOOD CONFIGURATION " AND THEN RESTART. THIS WILL SURELY SORT OUT YOUR PROBLEM.
PLS REPLY OR COMMENT. THANKS
When i turn on my computer it glitches and restarts repeatedly. need to do a system restore, but nothing seems to work. it is an emachines EL1200
Micahs
What triggered the problem? do you know? did you recently change anything? install any new programs? etc.
Do you get any error messages? Do you see the windows loading screen and then it just reboots again?
Try this first: HIt F8 when it is trying to boot, and if you get to select boot using Last Known Good settings. See if that helps. If not we can try something more advanced.
My laptop has been preparing to configure windows screen its been doing this for over 2 hours not sure what is going on with it
Bobby,
Please press F8 at boot up and boot in Safe Mode. Once booted, right click on the desk top and select Properties->Settings. Here Reduce the resolution of the screen display one notch and let it reboot normally after that.
If the problem still persists then Press F8 at boot up again and boot up in Last Known Good Boot. option.
Wont display the desk top
Try rebooting, tap F8 to get into the multi-boot options. Scroll down and choose "Last Known Good Configuration" windows should boot up normally. If you have made any hardware changes or if windows perfromed a corrupt update, that will require some additional help.
My HP Pavilion a 1600n wont let me long on goes to a black page tells me to press "r" for recovery i have no HP Pavilion a 1600n installation disc
k when the computer first boots up hit f8 or shift f8 to get to advance options . move arrows to last known good configuration. if that fails to get you on desk top you will most likely need to call hp and get replacement disks to reinstall the missing or currupted drivers. your NTloader is not reading from your master boot record that is why your getting this.
1helpful
Nothing on my desktop will open, no files that are on my desk top will not open not even when I try to open my hard drive.
You'll have todo a system restore on Vista or a Last known good configuration press F5 when booting up. ***WARNING*** you may lose some programmes / Files recently installed
Boot up
You may try "Last Known Good Configuration"
Boot the operating system with the “Last Known Good Configuration” feature. To use this:
  1. Restart your computer.
  2. When you hear a single beep or after the bios has read your hardware settings press [F8], this will display the “Windows Advanced Options” menu.
  3. Select Last Known Good configuration and press enter key.
Let me know.
Thanks.
Getting blue screen after start up
Try booting up to the recovery CD, it sounds like a software conflict error that is locking up your computer.
Try 1st if you can get into safe mode (hitting F8 when you first apply power to the computer, till the safe mode screen comes up)
Then try booting up to the last known good configuration (same F8 different selection on screen)
THEN try the recovery CD.
2answers
Boot-up
dot.gif How to load last known good configuration. Question: How to load last known good configuration.
Additional information: The "Last Known Good Configuration" option was first introduced in Microsoft Windows 2000 and is available in all later versions of Windows including Windows XP. This feature enables a user to load the last working version of Microsoft Windows. This is a great step to try when trying to fix issues with a computer not being able to load into Windows.
Note: Users able to open normal Windows XP mode and who wish to restore their version of Windows to an date before the last known good configuration may also wish to consider doing a system recovery in Windows. Additional information about how to do this can be found on document CH000589.
Answer: To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key. Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP safe mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the safe mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows. Will running the Last Known Good Configuration delete anything? No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
