Hotpoint TDL14 Electric Dryer Logo
Posted on Sep 16, 2007
Replacing the Drive Belt
I have a Hotpoint Dryer Plus 9314, Tumble Dryer and I need help to replace the Drive Belt. Diagrams would be helpful
  • 4 more comments
  • thefrog Nov 07, 2007
    skueak when dryer is on
  • soccer1 Jan 04, 2008
    whirlpool dryer mod#leq9858pw1. Need diagram on how to replace belt
  • trace0141 Jan 30, 2008
    the belt seems to small how do i get it to fit
  • Anonymous Mar 24, 2008
    belts slips
  • TERRIOR Jul 02, 2008
    DRUM DOES NOT TURN. BOUGHT BELT,991/8". REMOVED TOP,NOW I'M TRYING TO PUT BELT AROUND TUB BUT I THINK I HAVE TO REMOVE FRONT FIRST, BUT HOW? THANKS,
    P.S. DRYER IS HOTPOINT HEAVY DUTY, 20 YRS. PLUS.MODEL #DLL2880BACWH . THANKS AGAIN, GUS
  • Anonymous Aug 06, 2008
    where is the belt located in dryer to replace
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 03, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
553
Points
5
I am not an expert but I do have a Hotpoint 9334 Tumble Dryer which I guess is similar to the 9314.
To replace belt or heater element you must remove the front panel complete with door.
Screws are different sizes in different places so note where they belong as you remove them.
1. Remove 2 screws at rear top which go through the brackets holding the top panel, slide back the top panel a little and lift it off.
2. Pull off the rotary timer knob and remove 2 screws beneath.
3. This is the tricky bit! Remove the the plastic panel which covers the switches etc.. This panel has 5 plastic fingers which secure it to the metal plate behind, locate the ends of the fingers where they pass through the metal plate. Using a metal rod or punch and a hammer, tap the ends of the fingers to push them back through the holes easing each in turn a little at a time to avoid distorting the plastic unduly. (This is a bit scary as you have to hit them quite hard and the fingers look fragile)
4. Open the door and remove the 4 screws then remove 3 screws at the top and 3 screws at the bottom of the front panel. Lift and ease forward the front panel, unhook the door catch release wire, pull off the electrical connectors and put the front panel aside.
5. Lay the machine on its back and remove 1 screw holding the element housing to the top plate and pull off the electrical connectors.
6. Fit the belt around the drum, through the idler pulleys and over the motor spindle.
7. Put it all back together.
How to put belt on hotpoint dryer
Dryer Belt Replacement - YouTube
? 6:23
https://www.youtube.com/watch?v=dFB4vnmADh0
Jun 20, 2011 - Uploaded by Repairs101
How to do-it-yourself instructional on changing the drive belt on an electric ... She wanted to know about replacing the drive beltin her clothes dryer. ..... How to replace tumble dryer beltHotpoint, Indesit, Ariston, Creda, Proline ...
How to replace tumble dryer belt Hotpoint, Indesit, Ariston ...
? 9:36
https://www.youtube.com/watch?v=kNJGHyEPiJA
Jan 30, 2014 - Uploaded by how-2-repair.com
How to replace tumble dryer belt Hotpoint, Indesit, Ariston, Creda, .... to get right and the grooves correspond to the drive, so really obvious..
Dryer Drive Belt (part #WE12M29) - How To Replace ...
? 5:14
https://www.youtube.com/watch?v=ZXSJlWcZPiY
Oct 25, 2013 - Uploaded by AppliancePartsPros
Buy the new Dryer Drive Belt WE12M29 ... to replace the Dryer Drive Belt WE12M29 on GE, Hotpoint, RCA, Sears, and Kenmore dryers.
1helpful
2answers
Drum not turning
Hotpoint tumble dryer not turning? How to replace a hotpoint tumble dryer belt
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
Hotpoint TVF760 Aquarius + change belt
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
Aug 06, 2013 • Dryers
Cant get top off dryer vtd00
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Hotpoint vtd00p thermostat
It could be the thermostat has burnt out or possibly the start capacitor
needs replacing
3helpful
2answers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
3helpful
Reconnect wiring on a Hotpoint VTD00 tumble dryer
most electric dryers have a wiring schematic on the back or inside on the back pannel of the unit it self . try too look for one there and it might help you out
2answers
Tumble dryer drum won't turn
Jul 06, 2009 • Dryers
2answers
I need the procedures on how to change the drive belt on my Hotpoint VTD00G Tumble dryer. I've opened the top & front covers, placed the belt round the drum but I couldn't stretch the belt over the...
Apr 06, 2008 • Dryers
4helpful
2answers
Broken belt on hotpoint vtd65 tumble dryer
turn the macine aroun you wiil see3screws on the top holding the lid on remove these and take the top off there are 3or4screwes on the top in front of machine remove these lay the macine back at45degres and on the bottom of machine you will find 4more screws remove these and the front will come off place new belt over the drum and with a small crow bar linked through the belt and under the drive apply a lot of down presure to get it on to drive this is realy hard and you mey think the belt is to small it is not make sure u align drum in to front door or machine this is very simple then re assemble and away you go approx time45to hours work
Dec 06, 2007 • Dryers
Top Hotpoint Dryers Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
